TTR Stop Mounts
TTR Stop Mounts
I recently installed the Tranny mount and noticed a large amount of vibration. I know with solid mount some vibration is going to be there. I was wondering If anyone else has installed these and had the same issues?
You will have some, we are suprised to hear that if you have the TTR Upper engine mount, vibs are less... We have some customers you can ask for reference if you wish, let me know? Otherwise I am sure they will post here and let you know, that this is the case.
Vibs will also go done with time, as they break in a bit.
The STOP mounts are designed to have a more firm mount, to keep the engine from flopping around. We did not want to offer a product to not prevent movement. Movement helps with wheel hop, flex pipes from breaking, and also transfer the power better to the wheels.
I have the STOP mounts and have some vibrations, but it doesn't bother me! Feels very connected
This is what we hear from most. Shifts feel firmer, and you feel the car better.
Yeah, My vibrations are when I get going from a stop and it almost feels like the car is going to rattle apart. But if I give it more gas when starting it feels fine somewhere around the 1200rpm area
Agreed, mine felt like it was going to fall apart for about 500-1k miles, then it mellowed out a lot, and was a bit more bearable.
x2. it seriously feels like the car is going to stall. it took me a long time to get used to it. im now considering the upper mount and im wondering what its going to feel like with that sucker
Yes time helps the vibs a lot, it does not take much time either.
Many state having all poly mounts give less vibs than just having 1 of the mounts poly. It balances out the movement and doesnt let the vibs happen.
Last edited by TurboTechRacing; May 19, 2010 at 12:36 PM. Reason: Automerged Doublepost
nope. used an engine crane to hold the motor completely in place and a jack to the bottom of the engine so it doesnt go moving all over the place. i unbolted one mount at a time.
I have both the STOP Mounts and the Upper engine mount. I would say let your STOP mounts break in for about 1000 miles then get the Upper engine mount and have it installed and once that breaks in you should not have as much vibrations and the car should feel overall firmer.
It will go away! I had PM'd Aaron right after my install and thats what he told me, sure enough they did mostly go away. I did get some minor vibe's on cold starts or if I bogged teh car leaving a light etc..
After the breakin I had people get in my car and ask if I took them out
(I didnt) lol
(I didnt) lol
I think he's talking to the OP. Whenever you install rotated mounts (like the Stop mount) you need to loosen the top mount to let the engine adjust to its new resting position before torquing everything up.
Thats one thing I didnt know and didnt see in TTR's Instructions.
Here's John's instructions for the OTTP mounts (same thing).
https://www.cobaltss.net/forums/show...72&postcount=3
Since it's all torqued in there now, I'd say just loosen the top mount bolts and retighten them. That should let the mount shift without having to undo everything.
