Tuning : What Gains?
Old Apr 8, 2008 | 04:50 PM
Werewolf SS's Avatar
I looking into getting a tune so I was hoping to get some response from are pro dominant tuners here (area47 and the others):
While I know it's all theoretical and the gains can vary depending on tuner and car so just best estimate here.
My mods to date:
GM Stage 2 (42lb injectors, Belt)
Nate's 2.8 pulley
Ghetto Airbox Mod
Meth injection thru a 6gph nozzle 50/50 mix
filled tranny mounts
What should I tell the tuner to look out for and what gains do you estimate I'm going for a semi aggressive tune hoping to advance timing a good amount but not insane.
Thanks!!!
Old Apr 8, 2008 | 04:53 PM
Raven SS's Avatar
semi aggresive i would say 11.8-12.1 afr and about 20-22 degrees timing..ur gonna be pushing those injectors but meth will carry thru in the high rpms...
Old Apr 8, 2008 | 04:54 PM
ecotecon18s's Avatar
hey bro, just be careful if they tune it too aggressively for the meth and you run out, you will have a problem...
Old Apr 8, 2008 | 05:01 PM
INFE's Avatar
I would say thats pretty agressive! Im running 18 degrees of timing and a 11.4 A/F and look at my dyno numbers. Also get rid of those 42s and get 60s. I would not trust 42s and a 2.8 pulley.
Raven SS's Avatar
ur not running meth..meth allows u to run a leaner afr and tons more timing
Old Apr 8, 2008 | 05:04 PM
INFE's Avatar
yea your right about that but his injectors and his pulley size is not good
Old Apr 8, 2008 | 05:05 PM
Raven SS's Avatar
it is pushing it...but the leaner conditions and the meth he should be ok....should be being the key
Old Apr 8, 2008 | 05:07 PM
INFE's Avatar
yea but for $200 for 60s it wouldnt be worth the risk ( for me anyway)
Old Apr 8, 2008 | 05:09 PM
cobaltstg2's Avatar
he will be just fine with what he wants to do as long as the tuner doesnt go ape **** on the tune
Old Apr 8, 2008 | 05:10 PM
Raven SS's Avatar
me neither...
Old Apr 8, 2008 | 06:07 PM
Area47's Avatar
Rent me! per hour
i run 12.0-12.3 afr day in and day out. and 24 degree's of timing to 7800 rpms.
temperature plays hell with afr.
Old Apr 8, 2008 | 06:12 PM
Raven SS's Avatar
he said semi aggressive lol...
Old Apr 8, 2008 | 06:16 PM
Area47's Avatar
Rent me! per hour
bhaaaaaaaaaaaaaaaaa
go big or go home
Old Apr 8, 2008 | 06:17 PM
Psykostevo's Avatar
You're fine with your 42# injectors on that pulley. I have two of the cars I tuned with that pulley/injector combo hitting 13.4 @108, and that's without Meth, or a race tune. Straight 91 octane.
Those people end up having tranny problems though........but unrelated to the tune obviously.
Old Apr 8, 2008 | 06:27 PM
invisible's Avatar
Tranny Problems??? From keeping the 42's????
Old Apr 8, 2008 | 06:43 PM
Area47's Avatar
Rent me! per hour
please read the last line of what he typed.
Old Apr 8, 2008 | 08:30 PM
2.0freakotec's Avatar
when u got ur meth injection put in u would had to of gotten a tune, i just a tune done by DB performance and i gained 24 hp and 11 tq afr at 11.5 and not pulling any timing and not losing any hp all the way to redline
Old Apr 8, 2008 | 09:29 PM
John2k5's Avatar
why would he have had to have gotten a tune? meth cools the engine & blower down. It can be used just for that or to gain more horsepower threw a tune while keeping the engine and blower cool.
Old Apr 8, 2008 | 09:30 PM
You don't need a tune to get meth.
Meth cools the Heaton oops I mean Eaton down and brings IAT2 temps down and raises the octane of your gas by 7 to 16 points.
How are people hittin 13.4 with out a tune? Slicks?
Old Apr 8, 2008 | 10:56 PM
G85Cobalt's Avatar
but in order to install a meth kit you need a tune.?? never used before..lookin for a cooling mod that helps with power as well.
Old Apr 9, 2008 | 11:40 AM
To get the full benifit of meth you need a tune but if all you want is basicly cheap race gas and cooler IAT2 then you can hook meth right up and run it with out problems.
Any one here know or heard of a Tuner in Florida named Jeremy Formato?
I've been told he is a god among Vette, GTO, and LS1 vechiles. Also heard he
s tuned a few Cobalts any one know or have an opinion?
Thanks!
Anyone?
Heard of Jeremy Formato and know if he's tuned Cobalts?
Thanks!
Last edited by Werewolf SS; Apr 9, 2008 at 11:40 AM. Reason: Automerged Doublepost
Old Apr 9, 2008 | 11:43 AM
M-Dub's Avatar
I run an Area tune... 2.80 pulley on 42's... and running strong all day long!
2-* of timing, methanol and pulls like a somabitch!
Old Apr 10, 2008 | 05:29 PM
because if u run meth injection u dump more fuel in ur motor and ur injections work harder so if he runs out of meth the motor will go bye bye whenever u do meth u need a tune for it ur afr's could be in the 14-16's and thats bad
Old Apr 10, 2008 | 05:30 PM
Area47's Avatar
Rent me! per hour
nukka what?
Old Apr 10, 2008 | 05:36 PM
Raven SS's Avatar
lol we dont speak jibberish
