Tuning : What Gains?
Old Apr 10, 2008 | 06:14 PM
Kibosh3's Avatar
LMAO....cute
Old Apr 10, 2008 | 09:54 PM
firepinch's Avatar
Originally Posted by 2.0freakotec
because if u run meth injection u dump more fuel in ur motor and ur injections work harder so if he runs out of meth the motor will go bye bye whenever u do meth u need a tune for it ur afr's could be in the 14-16's and thats bad
But if you use the stage 2 tune, that tune is said to be rich. So in the end, having meth would bring up the afr right on the right region no? Like going from 10 to 11.5-12. Having meth would bring up the AFR that much (like from 10 to 14???)
Oh and why not at the same time... I just saw a reply saying that 42 lbs injectors with a 2.8 pulley isnt enough. I see some people saying yes and no to this. Whats the deal to run the injectors at 100% for a long time. If the IDC go above 100%, this will mean that the injectors will simply always supply the maximum they can, so in the end, this could even lean out the stage 2 tune a bit. Please if someone would like to explain to me if my logic is good or bad this would make my day!!!
ItalianJoe runs a setup with a 2.8 pulley and the 42lbs injectors for some big time and he doesnt have any problem with this yet. The 42 lbs injectors are supposed to be some pieces of great quality, so running them at 100% sometimes couldnt hurt?
Old Apr 11, 2008 | 01:42 AM
euthanasia's Avatar
Originally Posted by Werewolf SS
Anyone?
Heard of Jeremy Formato and know if he's tuned Cobalts?
Thanks!
Jeremy is a really good tuner. He is highly recommended on LS2GTO.com
Old Apr 11, 2008 | 01:54 AM
ItalianJoe1's Avatar
Originally Posted by Area47
bhaaaaaaaaaaaaaaaaa
go big or go home
Quoted for mother ******* truth!
Old Apr 11, 2008 | 07:25 AM
Werewolf SS's Avatar
For GREAT JUSTICE!!!!!
Take of Every Zig!!!!
Sounds good guys I might be getting my own HP Tuners if I can scrounge the money up and start light tweaking and buggin Area47 for help .
Old Apr 11, 2008 | 07:32 AM
Altiery54's Avatar
hows the meth working out for you?
Old Apr 11, 2008 | 07:51 AM
Till I get the new intake piping (comes in today woot!) to redrill the hole I messed up I can't give an accurate account. I will update my meth question thread after I've had time with it. I will say thou with the amount that does get in and isn't leaking in the engine bay the knock I used to get on my 2.8 pulley (upwards of 9 points!) is now 0.
Old Apr 11, 2008 | 11:25 AM
Area47's Avatar
Rent me! per hour
but your afr is in the toilet.
Old Apr 11, 2008 | 12:04 PM
Till I get a wide band I'll have to belive you
j/k.... How bad am I going down Area?
My reasoning was going lean with 2.8 would be subsituted with the riching of a 50/50 mix of meth/water.
Am I wrong please advise!
Thanks!
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Builttss
Oct 4, 2015 10:21 AM
goaliemo
Sep 28, 2015 01:37 PM
