Which Turbo?
Old Jan 25, 2010 | 12:19 PM
dougyfresh's Avatar
Which Turbo?
Ok i need some help deciding which turbo would be best for me. Im gonna have a stock motor and i want around 350whp or more. Sometime afterwards im gonna be putting pistons, ported head,and a couple other things. And when i do that ill put a bigger better turbo on then. Price is a BIG issue for me lol soooo that being said, any opinions?
Old Jan 25, 2010 | 12:54 PM
Leveecius's Avatar
Why not get the LNF stock turbo? We are hitting 350hp with it
Old Jan 25, 2010 | 01:21 PM
selfinfliction's Avatar
get an 88mm garrett and then use a 250 shot to spool it up
Old Jan 25, 2010 | 03:16 PM
dougyfresh's Avatar
lol yeah then my motor would **** all over the place lol
Old Jan 25, 2010 | 03:21 PM
Brenticus's Avatar
Hahn lvl. 5
Old Jan 25, 2010 | 03:23 PM
dougyfresh's Avatar
to much..... i can put a kit together for about half tht.....
Old Jan 25, 2010 | 09:28 PM
dougyfresh's Avatar
Old Jan 25, 2010 | 09:33 PM
get a quicker spooling setup on a 60-1
Old Jan 26, 2010 | 08:30 PM
dougyfresh's Avatar
Do yall think this would be to big?
COMPRESSOR SPECS:T04S
flow: 61 lbs/min 781cfm
.70 A/R housing
60-1 TRIM wheel
TURBINE SPECS:T3
.48 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!
Old Jan 26, 2010 | 08:32 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I've got a Precision SCM5031E that I'll be selling soon. Like $500. Good turbo... good punch... real fast.
Old Jan 29, 2010 | 02:06 AM
collins14ss's Avatar
yupp hahn stage 5
Old Jan 29, 2010 | 03:33 AM
ralliartist's Avatar
get a holset hx35. brand new turbo for around 400 bucks. Or get one used off ebay for 200 bucks.
Old Jan 29, 2010 | 12:28 PM
efrommel's Avatar
I have the same problem deciding which turbo. I was thinking: a t3 t4 .63 a/r 60-1 but i think will have too much lag for the streets idk.
What turbo you guys reccomend?
Old Jan 29, 2010 | 12:38 PM
Depends on what your idea of "too much lag for the streets" is... and also, your power goals.
Old Jan 29, 2010 | 12:41 PM
Dr.Balt407's Avatar
you can use a 50trim and make 350-400whp alone. go bigger and your looking at 70 rolls.
and you dont need to pay 5k for a hahn kit, 3k and you can have a way better kit that you put together yourself.
Old Jan 29, 2010 | 12:46 PM
a holset hx35 will be full boost at right around 3200ish rpms and support 550whp. and it will last 200,000 miles. Not bad for a 200-400 dollar turbo eh?
Old Jan 29, 2010 | 12:55 PM
ss88's Avatar
yup hahn is crazy money
Old Jan 29, 2010 | 01:12 PM
x2.3
Fo Sho. Has anyone put an HX35 BEHIND the block though? I know of someone that has put one beside the block... but I haven't seen anyone put one behind.
Big Turbo is Big.
Old Jan 29, 2010 | 01:14 PM
efrommel's Avatar
Well i want to do 40mph rolls on the streets and I am looking for 350-380hp
ralliartist: put a link to that turbo to see it. Its a good price. but its holset a good brand( I dont know nothing about turbos)
Dr.Balt407: Can you post a good 50 trim here to see it too?
Thanks
And sorry dougyfresh for the thread jacking Maybe we have the same questions
I have almost the same goals as you
Old Jan 29, 2010 | 01:49 PM
holset turbos are used on diesel engines. Specifically the dodge cummins engines and the bigger international big rigs. But the cummins motors use the smaller turbos that work perfect for the tuner scene. 500hp turbos that actually have really good spool time.
just search them, there is all kinds of good info on them on dsmtuners.com
http://www.dsmtuners.com/forums/turb...d-systems.html
Old Jan 29, 2010 | 01:55 PM
efrommel's Avatar
http://cheapturbo.stores.yahoo.net/gt2871r1.html
What you think about this turbo??
I know its expensive...
Old Jan 29, 2010 | 02:07 PM
that's a great turbo, it's just expensive.
Old Jan 29, 2010 | 02:19 PM
If you want 350-380whp... then a Garrett GT2876R/GT2871R would be perfect. Full spool around 3k, if not slightly before... and 15psi will net you right around 350whp.
Holset is an awesome brand.
You want a good 50trim, I've got one that I'll be selling here real soon. Precision SCM5031E. I'll sell it for like $500... I'll even have it freshly rebuilt for you so that you'll have nothing to worry about.
Old Jan 29, 2010 | 02:46 PM
Stiner's Avatar
Ya GT28 would be perfect but they are pricey. S247 would be a good choice also
Old Jan 29, 2010 | 02:49 PM
this is a good deal.
