Turbo Guys
Turbo Guys
I've got the car up on the hoist installing the turbo right now. I'm running the Vulcan turbo manifold and a T3/To4E turbo. Just wondering how close is too close to the firewall? It's damn tight fit and I don't know if the manifold will work after all. If it does fit, so far it looks like the cold side is gonna be against the firewall liner. So is this ok? I'm going back at it and I'll check for replies every so offen.
Ya, there is no way it's fitting in there right now, even if I get the adaptor. With the adaptor there is gonna be different clearence problems with the water pump area, and a air filter wouldn't fit then either. The problem is that the flange is dead center and it should be a little bit to the drivers side.
Do you guys know whats behind that insulation? I may end up removing it and denting the firewall a bit. It a matter of like an 1/8 of an inch. I just don't want to beat on the firewall if there is something there in the interior I may damage. Other then that I don't reall give a damn.
But I'm done for the night and tommorows a new day lol
Just hope you don't plan on selling it or anything like that lol
I fixed that issue with my old car by already having polyurethane engine mounts. That motor didn't move a centimeter lol
happy banging and try not to make any holes, your job is to dent not puncture.
my turbo is pretty close to the firewall too, actually with the new setup it sucked the fiberglass off of it lol, so I need to clean it up today and run the filter to a different location. My flange is dead center too and mine fit ok, maybe about 1.4" clearence to the firewall (at least the fiberglass) but it fits and doesn't hit under acceleration.
I've got engine and trans mounts so I'm not too worried about that. I can't even get more then 1 stuf in there. I'd have to pry the turbo up to get the other in. And then it will be jammed in there. I'll pull off the insulation off after work today and see what I can do.
Paul, I think your manifold it pretty much just like mine. Is the flange on a 45 degree pointing down? It looked like your flange was just barely to the driver's side a bit. Do you have any pic of the turbo in there? Or just the manifold?
Cool, thanks Paul. I pulled the insulation off and there is a plastic thing just kinda floating around on the passenger side of the firewall. I can shove it up in the hole and move it around. Just doesn't look right to me. Do you know what that it? Kinda looks like it has something to do with the HVAC or something. I was going to pull it out cuz it's in the way, but I thought I better find out what it is first.
hmm I don't know man, I'm pulling the insulation out today, I'll let you know when I see what it is you're talking about. My new turbo sucked the insulation off the passenger side firewall already anyway
Right on man! I will also let you know if I find out lol
Searchin Alldata now but nothing there
Last edited by BlackSS/SC; Jan 26, 2008 at 11:37 AM. Reason: Automerged Doublepost
wouldnt make sense for it to drain into that cushioning...i looked and im thinking im going to have the same damn problems....you could always cut the insul on the passenger side and leave it on the drivers side....get some heat rap or something....how much does the engine rock when you step on it? j/w because its looking like im just barely going to get it to fit..keep us updated on how everything goes
Alright, I got all the insulation off now and tried it again. Still no go! There is a small bump in the firewall right where the coldside sits. If I got it to fit it would rest right on that. I'd actually have to pry the turbo up a bit to get all the studs in, which I'm not gonna do. So it looks like that bump has to be flatened out and it will fit.
Paul, your turbo must just sit that little bit to the driver's side to clear that bump. The bump is only like 1 1/2 inchs wide and I'm hitting right in the middle of it.
Well I got it to fit. Fits just perfect now, just flatened out the little bump in the firewall and now I've got lots of room to spare!
Last edited by BlackSS/SC; Jan 26, 2008 at 04:51 PM. Reason: Automerged Doublepost
youve got a 50 trim and a vulcan mani? Thats good news man ima have to look at it...didnt hurt anything? and also how much room do you have behind there now? enough for the ngine to rock?
no mines a 60 trim, not installed yet motor is being built. i don't have to worry about much motor rocking, i have solid mounts.
If my manifold was moved over just a little bit, it would have been easier but that freaking bump in the firewall was tricky.
Well I'm done for today, got the rest of the winter to finish anyways lol. Got the turbo all bolted up & the oil lines ran. Here's a few pics.
This is where the turbo was hitting. Stupid me didn't take a pic afterwards. I can fit my hand easily behind the turbo now and have solid motor mounts so I should be ok.
