Turbo Lsj Help Needed
Old Jun 15, 2009 | 08:48 AM
Scott.Florschuetz's Avatar
I got the turbo in today just not intercooled, (straight pipe where intercooler goes for now) I am haveing a few bugs, If i come into boost a couple times like 1st and 2nd gear back to back the car shuts down and the little yellow light on the dash comes on. If i try to start it within the next 3-5 minutes it starts up but stutters BAD. after about 5 min it starts up ok again and runs fine. The boost controller is turned all the way down (i think its spiking 18 LBS) Ive tried a few different methods (stock tune, stock tune with imported MAF tables, the original tune from the car this kit came off) none of them fix this. Only thing i can think of is that i am still on the stock Plugs (hard time finding some colder ones) What do you think about this situation?
Also trying to make my mond up on plugs
NGK 2 or 3 steps colder
Denso 2 or 3 steps colder
Both are iridiums
Old Jun 15, 2009 | 08:55 AM
Zach06CobaltSC's Avatar
I would purchase a better tune from someone who knows what there doing personally.
Old Jun 15, 2009 | 09:05 AM
This tune is from a Colbalt i imported the specs to my redline (the turbo kit was on the cobalt and it ran fine)
Old Jun 15, 2009 | 09:24 AM
ShortStack's Avatar
You said you put on a stock tune.. just making sure you changed the injector offsets?
How is it hard to find one step colder plugs? You can get em anywhere..
3 steps colder is wayyyy too much.. 2 steps colder in fact is over doing it... 1 step colder will be fine... but thats up to you.
Stay away from Iridiums... Boost likes copper plugs better.
Old Jun 15, 2009 | 09:30 AM
Maxim_X's Avatar
First off, find a way to lower your boost, you don't start tuning @ 18 psi.
Get plugs immidiatly
Next, where is you MAF mounted?
What size injectors do you have and what size did the Cobalt have?
Do you have a wideband? What does it read?
Old Jun 15, 2009 | 12:42 PM
BlackSS/SC's Avatar
He's got my old turbo kit, I sent him a list of what to do in the tune. He's all set...
Old Jun 15, 2009 | 12:49 PM
Jazer's Avatar
I personally WOULD NOT be running that much boost non-intercooled.
Also, which little yellow light? The engine? Go figure out what codes its throwing..
Old Jun 15, 2009 | 02:26 PM
06noscobaltss's Avatar
You are going into limp mode. Thats why the light comes on and why the car shudders when you start the car up right away. Keep an OBDII reader in your car. When the light comes on, erase all of your CELs and it will start right up and run normal. Go get a real dyno tune, you def. need an intercooler, and 18psi with no intercooler and no tuning is not a smart idea. Prob would benefit from a ported head as well.
Old Jun 15, 2009 | 06:04 PM
LOL in trying toward the head man.... just the little expenses eating me up. As far as codes 0121 1184 TPS and Inlet pressure sensor. i have the same injectors and the maf is mounted in the same stock location. any part numbers on some copper plugs?
Old Jun 15, 2009 | 06:06 PM
ngk bkr7e go with those from ottp.
edit: that head would be SICK on your car too, i would grab it if i wasn't already porting my head and didn't already have valve springs and stuff for it.
Last edited by Zach06CobaltSC; Jun 15, 2009 at 06:06 PM. Reason: Automerged Doublepost
Old Jun 15, 2009 | 06:10 PM
BlackSS/SC's Avatar
Just get the plugs from an auto parts store, I don't know why anyone orders them anywhere else, waste of time...
NGK BKR7E
Old Jun 15, 2009 | 06:25 PM
Kennyspec's Avatar
what injectors are u running, using hptuners to tune it? 18psi and no intercooler is a time bomb.....running maf blow through?
Old Jun 15, 2009 | 06:29 PM
BlackSS/SC's Avatar
60lb injectors, my old base tune, hp tuners, blow through maf after IC and BOV near the throttle body. He should be running the IC for sure. Not sure why he isn't right now.
Old Jun 15, 2009 | 06:36 PM
IC is going on tomorrow i ran my Z at about 20lbs with no IC but right n ow the intake temps get no higher than 150.
Old Jun 15, 2009 | 06:42 PM
BlackSS/SC's Avatar
Good to hear!
Spanky's Monkey
Mar 7, 2016 06:06 PM
Josh@ottp
Sep 17, 2015 12:03 PM
n20saturn
Sep 17, 2015 01:55 AM
Josh@ottp
Sep 8, 2015 10:18 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
