questions on interceptor gauge
i just installed my gauge today and had some questions:
1. isn't it soppused to say "cobalt ss" when it starts up? mine doesnt
2. what all parameters do you guys have it looking at? not sure what all we had so i check marked all of them.
pretty sure mine just says ''ss edition'' not sure tho ill have to check tommarrow...i only have a single gauge so i watch knock retard and iat2... i think most people will say they watch iat2's, and since im on meth i like to watch for knock just in case
also, how do you set the shift lighs up?
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/how-operate-interceptor-175607/
looks at my post (last post) for the shift light, I did a step by step. hope it helps!
ok i found the logo section so that is good. also i think i set my shift light up right. havent had time to test it yet.
so what 2 items do you guys display? right now i have iat2 and hp
https://www.cobaltss.net/forums/showthread.php?t=175607
What is the normal HP that shows up on your display? LOL.. I installed my Interceptor today and at idle it says I have 6 HP and it only hit like 90 HP. lol... but I had the battery disconnected and it says that it gets the HP figure from the air flow and the mpg for fuel. Since I disconnected the battery and I just started it up it says I only have gotten 8 MPG so I don't know what to say. LOL. Maybe if I drive it a bit more the HP number will change.
I have a 2009 Pontiac G5 GT and just wanted to know what it said for HP before I installed my SC kit.
you set your own HP in a section. For fun I made my HP 900
and it changes with how much gas you give it and such
the logo thing should be the last option on the main menu sooo check there?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
