Turbo Removal
Old Jul 22, 2011 | 01:05 AM
CarbonFiber112's Avatar
Turbo Removal
Hello I have a 06 lsj converted to a turbo and there is a major oil leak I think coming from the turbo. I am going to try and pull it tomorrow and find the leak but I have never done it before. Is it an extremely difficult task and do I have to drain anything before I start to unbolt it and what should I start unbolting first?
Old Jul 22, 2011 | 01:10 AM
Omnigear's Avatar
clean engine bay, with gunk spray. wash it down, and drive it see where the leak is comin from.
you think and it is are two different things. find the leak b4 u start tearing things a part.
spray gunk where the majority of the oil is at as best as you can. helps trackin down the problem.
Old Jul 22, 2011 | 10:21 AM
ok well a mechanic saw the oil on the turbo and so do I. He said he was guna charge me $250 to take it apart and see if I need a rebiuldor a new turbo. So I was planning on taking it off myself and bringing it to him just to save the money.. Also can bad piston rings cause the turbo to leak?
Old Jul 22, 2011 | 10:44 AM
Omnigear's Avatar
so what if theres oil on the turbo, the wind can blow the oil on the turbo. like i said clean your engine then drive it then look for the oil leak. No bad piston rings cannot directly cause the turbo to leak, true story dot com
Old Jul 22, 2011 | 10:53 AM
ccbalt22's Avatar
im a supercharged guy but i know turbos... clean it. i dentify exactly where it comes from. it might save u a ton of work.
Old Jul 22, 2011 | 10:55 AM
BartSS's Avatar
i have a little oil on the turbo... like theyre saying clean it up and see where its coming from... also did you buy the car swapped or did you do it?
Old Jul 22, 2011 | 06:55 PM
I bought the car with the turbo in it. its a turbonetics kit. I am going to clean the engine tonight then look for the leak after. It looks like the fresh oil is coming out of the oil drain tube that goes to the oil pan because it looks pretty wet when I am done driving it. Should I unbolt that or what???
Old Jul 22, 2011 | 07:07 PM
startingline05's Avatar
check the line on top where the oil line goes into the turbo, that is more then likely going to be where the leak is coming from if theres oil on the turbo. undo the line and put some thread tape on the fitting and screw it back in. and while your doing that make sure the clamp holding on your return oil line to the oil pan is tight. if this doesnt solve your problem then you might actually have some kind of problem lol.
Old Jul 22, 2011 | 07:17 PM
Oh yeah and there is a lot of smoke coming from the turbo area so its not a minor leak beacause im constantly adding oil
Old Jul 23, 2011 | 04:47 PM
It has a turbo with something on the side that says A/R .50 does anyone know what kind of turbo that is???? Because I am trying to figure out if I can buy a bigger one but I need it to be able to it bolt on without problems? And one of my cylinders read 100 during a compresssion test so what should i get fixed first?
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
