turns over but doesnt start!!!!!! WHATS WRONG
Old Aug 23, 2008 | 05:20 PM
thatotherguy's Avatar
My car turns over but doesnt start.. i checked the bleed valve for the injectors and theres no gas that comes out of it. and i have a CEL but dont know what it could be because i dont have a scanner
Yall please help me
Old Aug 23, 2008 | 05:23 PM
06SS/SC STAGE2's Avatar
Bad fuel pump? Maybe. Got to have fuel, air, and spark. When you turn the key on can you hear the fuel pump starting up?
Old Aug 23, 2008 | 06:10 PM
im not sure i hear noises like my intake and some other things but i can pin point it. fuel pump is in the back right?
I had to get a new wire harness because my old one had wires showing. so i dont think its the new harness
Last edited by thatotherguy; Aug 23, 2008 at 06:10 PM. Reason: Automerged Doublepost
Old Aug 23, 2008 | 06:21 PM
Yes pump is in the rear. Not sure on these cars if its external or in the tank. When you tuen the key you should hear a quick and slight buzzing for a second or two. Thats the pump priming the fuel system.
Old Aug 23, 2008 | 06:26 PM
I hear like a high pitch whistle noise but its not that loud thou
Old Aug 23, 2008 | 06:28 PM
blu3_v1p3r's Avatar
check your plugs and tell us what you see.... that can kinda determine a lot....
what harness and when did you do this? has the car ran since you changed it?
Last edited by blu3_v1p3r; Aug 23, 2008 at 06:28 PM. Reason: Automerged Doublepost
Old Aug 23, 2008 | 06:29 PM
HunterKiller89's Avatar
check ur spark plugs, and if you want, take out an injector and see if fuel flows from the rail. The bleed valve on mine doesnt flow anything, but when i took out the injectors, you bet your ass gas was flowing.
either u gt no fuel or no spark. bad plugs would be the first thing to check for no spark, and making sure fuel is in the fuel rail is the fastest way to make sure your getting fuel. Double check your connections for the fuel rail wiring harness as well
Old Aug 23, 2008 | 06:35 PM
theres not fuel in the fuel rail and i just put new ngk iridium plugs in a couple weeks ago
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
roth
Sep 26, 2015 12:16 PM
