Tvs 1900 lsj build
Old Jan 23, 2012 | 01:24 AM
100% METH's Avatar
Thumbs up Tvs 1900 lsj build
Couple months back I decided it's time to replace my 116k engine in my 07 SS/SC.
Heres the list:
Short Block
Euthanasia's LSJ sleeve girdle (In progress until other goodies are in)
Diamond 9.5:1 Forged Pistons -
Total Seal Gapless ring set -
ATI Crank Pulley -
Neutral Balance Shaft Delete kit -
K1 H BEAM Rods -
Main & Rod bearings
stock crank
Balance the entire rotating assembly - Waiting for rods to arrive
End result should be a 8k redline or higher
HEAD
Supertech springs & retainers
valves-
valve guides -
Aggressive head port (Done by none other than Euthanasia here on CSS)
GMR cams -
Bates Solid lifters
Transmission
My trusty 116k LSD Trans
gmpp clutch -
flywheel -
lnf revised shifter bracket -
B&M Short shifter w/ solid bushings
Exhaust & Intake
CIA Ceramic Coated Midlength | high flow DP w/ cut out
22" Smithys 2.5/2.5 muffler as resonator to a stock lsj muffler
ZZP 3" INTAKE -
LS4 Throttle body -
Power ADDER
Euthanasia Magnuson TVS 1900 - pending
Euthanasia Magnuson MP90 - Sitting in the garage awaiting patiently...
COOL DE MODZ MAHN!
Completely stock LSJ intercooler system
Alcohol Injection Systems Single stage water/meth kit
Fueling
I've love to stay on 60s... but I think I'm finally going to have the up the anti to 80 lbers....
WATER/METH Courtesy of AIS
HP PREDICTION...
Lulz?
Over all Appearance
The car has been painted bright white
Its rolling on stock FE5 Suspension & springs
Stock LSJ wheels
It looks like a rental car
Some pix...
Beginning stages of porting the head
Stay tuned...
Old Jan 23, 2012 | 01:27 AM
FryLoch's Avatar
Holy ****.
Old Jan 23, 2012 | 01:44 AM
100% METH's Avatar
Originally Posted by FryLoch
Holy ****.
You think it's to much?
Old Jan 23, 2012 | 01:50 AM
BLue NoTe's Avatar
Yeah way too much lol. Glad to see you got those GMR cams
Old Jan 23, 2012 | 01:51 AM
thedubsack85's Avatar
Subbed! In for results and i cant wait to drive it!
Old Jan 23, 2012 | 01:52 AM
100% METH's Avatar
thanks
Block is getting tanked any day now... Need to order those rods to get the bottom half started
Old Jan 23, 2012 | 01:54 AM
InfraRedline's Avatar
Sub'd
Old Jan 23, 2012 | 01:55 AM
DiabeticKripple's Avatar
subd
advise's Avatar
sounds fun, cant wait for some numbers
i pm'ed Euthanasia about a quote and never got a response
BLue NoTe's Avatar
Pulley size and redline?
Old Jan 23, 2012 | 01:59 AM
100% METH's Avatar
His computer got a gnarly virus the other day
I need to make the drive out fix it...
He will get back to you asap
Havn't decided yet
When I ran the 1900 on the motor box stock... it was doing 25 psi on a 3.6 pulley.
Given the head port, cams... I wanna keep it below 18 psi to maintain peak efficiency
redline will be 8192 - Thats as high as HPtuners will allow me to go
I would love to know how ZZP went higher
Old Jan 23, 2012 | 02:00 AM
Omnigear's Avatar
chuck norris pulleys?
Old Jan 23, 2012 | 02:01 AM
100% METH's Avatar
Forged from his beard
Old Jan 23, 2012 | 02:02 AM
SunburstSS's Avatar
Holly shyt that's huge....lol
Subd for results as usual
Old Jan 23, 2012 | 02:09 AM
BLue NoTe's Avatar
I'd play it safe and keep it to 8190 rpm
Old Jan 23, 2012 | 02:10 AM
100% METH's Avatar
lol... it's going to be wierd reving that high...
Old Jan 23, 2012 | 02:11 AM
Blowncavy's Avatar
Great build man, can't wait to see this come along
Old Jan 23, 2012 | 02:14 AM
Omnigear's Avatar
hope its 400awhp when its done ^_^
Old Jan 23, 2012 | 02:15 AM
thebucky84's Avatar
wow.... lol
Old Jan 23, 2012 | 02:17 AM
is this your job or something?
Old Jan 23, 2012 | 02:18 AM
100% METH's Avatar
Why do you think that?
Old Jan 23, 2012 | 02:22 AM
cause your always doing lots of testing with alot of setups
lxl_Th3_On3_lxl's Avatar
What in the world is that beast?!
Old Jan 23, 2012 | 02:25 AM
100% METH's Avatar
I do it for fun
It helps to know people, who know people, who know people?...
Magnuson TVS 1900 (1.9L s/c) adapted to our manifold by Euthanasia
Old Jan 23, 2012 | 02:26 AM
Sharkey's Avatar
im sure you know already, but thats the limits of the factory pcm, not just hp tuners. i believe the zzp drag car that layed down 898hp used a stand alone fuel management
