Tvs 1900 lsj build
Old Jan 23, 2012 | 11:38 AM
  #51
FryLoch's Avatar
I want this setup! Where did this blower come from?
Old Jan 23, 2012 | 01:43 PM
  #52
zfissette's Avatar
fairly sure the zzp 898hp car used 8 injectors and was run by a stand alone, easy enough to check the thread to verify that.
Old Jan 23, 2012 | 01:46 PM
  #53
Omnigear's Avatar
i thought zzp had a piggyback
Old Jan 23, 2012 | 01:48 PM
  #54
Leafydialupking's Avatar
For the 400 hp blower car they did IRRC they disconnected the speed sensor and that got rid of the 8192 rev limit, BUT tuning up there is done by the computer interpolating the last cell with god knows what so it ******* lala land. If you want to do it parallel wire in a standalone (aka give the stock computer just enough info to run the gauges and let you pass emissions).
Those cams are going to hold you back.
Old Jan 23, 2012 | 01:57 PM
  #55
Sully20's Avatar
Originally Posted by 100% meth
just need staged07ss with the h62 and we're set!
^^^this^^^
Sub'd....This Build is ****
Old Jan 23, 2012 | 02:48 PM
  #56
Bluelightning's Avatar
Got Bewst?
Sweet mother of god that's a big blower! Good Luck! Suuuuuuuub'd
Old Jan 23, 2012 | 03:21 PM
  #57
mrbelvedere's Avatar
they ran 190lb an hour injectors and stock ecm system
Old Jan 23, 2012 | 03:22 PM
  #58
SCcobaltSS's Avatar
Originally Posted by mrbelvedere
ther ran 190lb an hour injectors and stock ecm system
This is what I thought too.
And I thought I read they did something with the VSS to get it over 8192 RPM (or whatever it maxes at)
Old Jan 23, 2012 | 06:24 PM
  #59
Um also, euthansia block guard?!
Old Jan 23, 2012 | 06:35 PM
  #60
Maven's Avatar
in for teh lulz
Old Jan 23, 2012 | 06:59 PM
  #61
RooTBeeR's Avatar
TVS 2300 or bust
1337 powa
iirc, to rev over pcm limits you need to move/change the abs crap on the front wheels so it reads different. decent bit o modding
Old Jan 23, 2012 | 07:55 PM
  #62
advise's Avatar
can some one verify how above 8192 was achieved
Old Jan 23, 2012 | 09:30 PM
  #63
100% METH's Avatar
Old Jan 23, 2012 | 09:35 PM
  #64
Cefaln452's Avatar
looks slow
Old Jan 24, 2012 | 12:35 AM
  #65
100% METH's Avatar
Originally Posted by Cefaln452
looks slow
Old Jan 24, 2012 | 12:36 AM
  #66
383_Stroker's Avatar
Way to step it up... Jerk...
Old Jan 24, 2012 | 12:43 AM
  #67
100% METH's Avatar
why is that?
Old Jan 24, 2012 | 12:44 AM
  #68
100% METH's Avatar
still has a couple months left until completion...
been working 5-6 days weeks averaging 40-44 hrs to make this happen
Old Jan 24, 2012 | 12:49 AM
  #69
Originally Posted by 100% METH
why is that?
I havent seen the specs on them but from what I've seen in the cam sticky they're not all that aggressive nor impressive. And when they were designed there was certainly no way that they even considered the fact that you could be trying to cram as much air though the valves as you are, nor how ported you head is/will be. They'll be better than stock, but I bet if you havent bought them yet you can get someone to get you a custom re-grind. I'm thinking something in the nature of the most life your valve springs can handle, with a ramp angle as aggressive as possible to not damage the lifter faces or valve seats, though I dont know enough about cam design to comment on duration or overlap.
Old Jan 24, 2012 | 12:50 AM
  #70
100% METH's Avatar
Originally Posted by Maven
in for teh lulz
I think so
  #71
BlackMagic's Avatar
Reppin for them sc Balts
Old Jan 24, 2012 | 12:51 AM
  #72
100% METH's Avatar
Area47 posted a nice gain with them without even giving the tune really any beans.
Euthanasia tells me theyre pretty aggressive
Old Jan 24, 2012 | 12:52 AM
  #73
cole3883's Avatar
holy ****
Old Jan 24, 2012 | 12:59 AM
  #74
We shall see. I just looked back at the test and also noticed that he was running a pretty conservative tune, more conservative than the rest with the GMR cams as well. Still, I would expect less drop off with super aggressive cams.
Old Jan 24, 2012 | 01:06 AM
  #75
mofofernando's Avatar
subd should be pretty intense
