Tvs 1900 lsj build
Old Feb 3, 2012 | 04:59 PM
  #301
ebristol's Avatar
Wait...
Old Feb 3, 2012 | 05:00 PM
  #302
mrbelvedere's Avatar
Originally Posted by advise
how are you guys running the breather lines
2 an fittings on the back of the valve cover
also your deleting the pcv in the head?
get a weld on male mung from summit racing weld on the v.c. inline with the vent and one on the intake
Originally Posted by 100% METH
So would if it were ran that way, would it draw in unmetered air?
with a open air filter it will draw unmetered air in it needs to be sealed
Should I instead just cap the intake and run the pcv line to that moroso can with the breather and just let it vent. Similar to a breather on the oil cap, just without the mess?
run a line from the v.c. to the air oil sep then to the intake dont use a atmosphere breather it will pull unmetered air in
Originally Posted by ebristol
It shouldn't. Most connect to the intake before the Maf.
if you use a atmosphere breather in the system it will
So under a vacuum with the breather it won't draw in air thru the breather and into the intake?
yes it will
I understand how it wouldn't under wot due to it being positively pressurized. All the vapors, exhaust gases would just go out the breather.
I'm just going to get that nice baffled moroso billet oil/seperator...
plug the pcv port in the head also
Old Feb 3, 2012 | 05:02 PM
  #303
No. It should.
Everything should be metered if you hook up the vent line/breather to the intake.
The line that goes to the intake is before the Maf sensor. So anything going through that line will pass by the maf both in Vacuum and boost.
if you run a breather on the oil cap it will pull unmetered air in the system needs to be sealed
Old Feb 4, 2012 | 02:33 PM
  #304
euthanasia's Avatar
If the 1900 works out good I know how to get one of these lol
Old Feb 4, 2012 | 03:33 PM
  #305
RooTBeeR's Avatar
Muahahahaaaaa!!!!!
you dont happen to have thet dyno yet, do you?
Old Feb 4, 2012 | 04:00 PM
  #306
ebristol's Avatar
2300! lol
Do it!
Old Feb 4, 2012 | 04:15 PM
  #307
euthanasia's Avatar
Originally Posted by RooTBeeR
Muahahahaaaaa!!!!!
Not yet. Vortech is trying to get me to buy there AWD dyno for 50k lol Its brand new never ever used lol I guess they paid 100k for it. I might get a engine dyno first then the chassis dyno a bit later.
2300! lol
Do it!
Maybe I know my new ported head will take what the 2300 can give.
Old Feb 4, 2012 | 04:16 PM
  #308
100% METH's Avatar
2300! lol
Do it!
All depends
Plugged some numbers in
If we can have a 4.5" pulley made for the TVS 1900.
Depending on how well the head/cam combo flow, it should only rob 30-35 hp and stay above 70% isentropic efficiency. Everything else will follow suit..
The funny part is it will **** out cfm wise what the TVS 1320 does on a 2.5-2.7 pulley depending on the rpm.
I need to see how it pans out with the 1900 PSI wise vs RPM. If it ends up being to small, I'll purchase a 2300.
Old Feb 4, 2012 | 04:43 PM
  #309
euthanasia's Avatar
All depends
Lysholm 2.3L lol
Old Feb 4, 2012 | 04:50 PM
  #310
100% METH's Avatar
Originally Posted by euthanasia
Lysholm 2.3L lol
those are so much damn money
for the Money vs HP ... better off just using that TVS 2300 laying around
Oh and how difficult is it to wire up a tach that reads past past 8k? Do they sell small ones that can sit right in front of my stock one?
Old Feb 4, 2012 | 10:41 PM
  #311
thedubsack85's Avatar
Yes they have 10K rev limit tachs out there, Can you toon above 8K is the question! i cant wait for this....
Old Feb 4, 2012 | 10:54 PM
  #312
100% METH's Avatar
yes, I have figured out the secret lol
more like a friend pointed me where I needed to go and I used my noggin to figure out how it worked...
Old Feb 5, 2012 | 01:03 AM
  #313
advise's Avatar
what redline you aiming for 8500?
Old Feb 5, 2012 | 01:09 AM
  #314
pretty sure he said highest he can go is 8192, couldve been different thread though.
Old Feb 5, 2012 | 01:14 AM
  #315
advise's Avatar
thats what hp tuners limits you too but theirs a way around it
Old Feb 5, 2012 | 01:17 AM
  #316
the stock pcm cant read past 8192 IIRC, But i guess there is now more than one person who know's how to toon past that RPM(IIRC ryans car @ZZP was revving past 8192 and was the first/only From what i recall) as far as what rpm exactly i cant say i dont know but im guessing atleast 9k, But ill sure take it past 8192 at the track as long as he gives me the go ahead if not ill keep it at 8100. I have a lead foot when needed!
Old Feb 5, 2012 | 02:06 AM
  #317
freakta's Avatar
These cars sound crazy over 8k... I'll eventually run mine way up there
Old Feb 5, 2012 | 02:21 AM
  #318
100% METH's Avatar
The in gear modifier in under fueling in hptuners
its based on a multiple of 0-2.0. Stock is set to 1.0 so it just multiples by 1 and lets the other modifiers do what you set them too.
So I'm assuming if you set the in gear modifier to 2.0. It will multiply what ever you set fuel to cut off @ by 2. And since our ecm limits to 8192... 8192 x 2 = 16,384 rpm...
Ah forgot to mention the in gear modifier in hptuners is based on coolant temperatures. You can control redline based on your coolant... kinda handy feature
Old Feb 5, 2012 | 02:26 AM
  #319
100% METH's Avatar
I'll rev to whatever it makes power too
Old Feb 5, 2012 | 02:36 AM
  #320
Its Over 9000!!! [Original Video and Audio] - YouTube
Old Feb 5, 2012 | 02:38 AM
  #321
100% METH's Avatar
lulz~!!!!
Old Feb 5, 2012 | 02:39 AM
  #322
if you rev to 9k that would be pretty damn orgasmic.
Old Feb 5, 2012 | 02:54 AM
  #323
100% METH's Avatar
I'd say...
Old Feb 5, 2012 | 02:58 AM
  #324
*splooge*
Old Feb 5, 2012 | 03:12 AM
  #325
Sharkey's Avatar
*splooge*
cleanup on page 13!!!
