TVS Boost Problems
Old Jul 30, 2009 | 02:39 PM
crt013189's Avatar
TVS Boost Problems
Hey guys I took my TVS to Hahn yesterday to get tuned and during the tuning process we lost about 5lbs of boost. So it was only boosting around 15lbs instead of the 20 or 21lbs it usually does. We also found out that when we bypass the boost bypass valve the boost comes back to 18.5 19lbs. So not all the way back to 20 21lbs like I would want to see. Does anybody have any ideas as where to look too see if I can find the problem.
Thanks
Old Jul 30, 2009 | 02:43 PM
Deathscythe's Avatar
the boost bypass valve was my problem, so I don't know. Maybe a little belt slippage?
Old Jul 30, 2009 | 02:46 PM
crt013189's Avatar
do you know what exactly failed on it and did harrop cover that under warranty at all. Im just wondering if anybody else had some problems similar to me im working on getting the log from Hahn so everyone can see what it looks like.
Old Jul 30, 2009 | 05:16 PM
Snakes709's Avatar
iiunno what that issue could be...only issue i have is my boost gauge is maxing out at 30psi....because i swapped the SC gauge for the TC gauge..lol. did u hook all the lines up correct?
Old Jul 30, 2009 | 06:37 PM
crt013189's Avatar
Yeah it was working fine before then we got it up on the dyno and after about 11 runs the boost went down to 15psi but I did the boost bypass and it went back up to around 19 but not hitting the max of 20psi
Old Jul 30, 2009 | 07:03 PM
Snakes709's Avatar
clogged cat? exhaust leak?...iiunno
Old Jul 30, 2009 | 07:16 PM
crt013189's Avatar
Clogged cat would cause more backpressure resulting in higher boost and I'm almost 1000% the exhaust is ok I'll get the logs up in a little bit so everyone can see what's going on
Old Jul 30, 2009 | 07:30 PM
Snakes709's Avatar
ah...my bad...iiunno man thats weird. I wanna say u have a vacuum leak somewheres but i cant be certain
Old Jul 30, 2009 | 07:56 PM
Jared B's Avatar
i had the same problem i just unplugged the boost bypass and it was fixed.
Old Jul 30, 2009 | 08:34 PM
freakta's Avatar
ya same here. unplugged the bypass and it is where it should be at 15psi... until i dropped pulleys hahahaha.
hey jared got the new numbers didnt do to bad... but like you ive got a 2.5in downpipe so thats my next project. when we swap them ill let you know how it goes
Old Jul 30, 2009 | 08:35 PM
freakta's Avatar
Old Jul 30, 2009 | 08:42 PM
hungryhip-ccp's Avatar
so what kind of numbers was it putting down even though you had probs?
Old Jul 30, 2009 | 09:03 PM
freakta's Avatar
if your asking me i did 312hp and 265tq
turbochargedss2012
Sep 20, 2023 12:17 PM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
