TVS install help
Old Oct 7, 2010 | 03:24 PM
startingline05's Avatar
TVS install help
i installed my tvs supercharger i got from ottp. i have everything hooked up. but when i crank my car it wont idle right. it jumps up to almost 3000 rpms and trys to die. it does this over and over. any ideas one what the problem might be?
Old Oct 7, 2010 | 03:35 PM
ebristol's Avatar
Sounds like your car is allergic to the TVS. Send the TVS to me!
Old Oct 7, 2010 | 03:41 PM
Nacademus's Avatar
Did you undo the battery terminal?
Old Oct 7, 2010 | 03:43 PM
Snakes709's Avatar
did you retune the car? Any air leaking out anywheres?
Old Oct 7, 2010 | 03:46 PM
ChevyRockstar's Avatar
check all vacum lines? MAF?
Old Oct 7, 2010 | 03:53 PM
wantedSS/TC's Avatar
how big are your injectors?
reason I ask is bc the car that I helped install a TVS on ran almost perfect at idle with 80#.
Was kind of shocking in all honesty
Old Oct 7, 2010 | 04:03 PM
they are 80's and all my sensors are hooked up fine. one thing i noticed is some kinda boost line that hooks up underneath the supercharger is almost to short and to get it to fit on stretchs the line out alittle and maybe its pinched. i ordered the ottp stage 3 kit so it did come with a tune.
Old Oct 7, 2010 | 04:16 PM
Snakes709's Avatar
ah i know what u r talking about, trying to think how i hooked mine up. If i remember correctly that line runs beside the engine, cant remember what the part it is called but it is bolted on. Unbolt it and bring it closer to the blower. Its right above my tb in this picture
And the line that is resting on the edge of the blower(shiny line) in this picture, u can see where it runs to
Old Oct 7, 2010 | 04:42 PM
yea its the one that hooks up the that bypass selanoid underneath the super charger. thats the only thing i can think of that has it not idling right. and when i touch the gas just alittle it jumps up to 3000 rpms and just stays there
Old Oct 7, 2010 | 04:44 PM
actually i dont know if this will cause it to not idle right but the injector harness the 80's came with i never replaced cause i had 60's on there before, but the 80s snapped right in so i never worried about replacing it. i might have to throw the 60's back in with my old tune and see if it runs right, maybe i got a bad tune from ottp
Old Oct 7, 2010 | 04:48 PM
BLAZIN07SS's Avatar
I'm too JDM for you
doesn't sound like tune. sounds like a bad vacuum leak
Snakes709's Avatar
could be possible, what was your old tune like. I ran the tvs for 2 weeks, didnt hammer on the gas though with a tune for 60's/2.8 and meth for the m62 and it ran fine so u could get away with that. but try checking the line first. then, check your tune.
Old Oct 7, 2010 | 04:52 PM
my old tune was a tune from a shop that dyno tuned it for 60's and a 2.6. if thats the case i guess im gonna need ottp to send me another tune when ever they wanna re open
Old Oct 7, 2010 | 05:03 PM
Snakes709's Avatar
Just make sure its the tune before you call them about that. Or try and get a hold of josh and he can probably help you with the issue.
Old Oct 7, 2010 | 05:06 PM
383_Stroker's Avatar
x2...
Old Oct 7, 2010 | 05:12 PM
InfraRedline's Avatar
Did you maybe crack your MAP sensor when you rotated it and now its leaking?
Old Oct 7, 2010 | 06:17 PM
no i cracked my map sensor the first time i did it and my new one came in the mail today, so i shaved it and put it on and it fit just fine this time, i fixed the vacum line that goes the the bypass under the supercharger and still idles funny. the only thing i got left to try is the tune, so im about to throw my 60's back in and my old tune to see what it does
Old Oct 7, 2010 | 06:38 PM
well before i do this i messed around with it and let it run and now it just stays idling at about 2800rpms
Old Oct 7, 2010 | 06:50 PM
How was the condition of the IM gasket
Old Oct 7, 2010 | 07:28 PM
you sure the SC is seated well on the IM? and the tb is sealed well on the sc?
Old Oct 7, 2010 | 08:42 PM
actually i figured it out, it was the gasket that goes on the endplate, i feel stupid for not catchin that one, but thanks everyone for your help, car runs great cant wait till the 2.8 pulley comes in now
Old Oct 7, 2010 | 10:13 PM
jaxonvain2.0's Avatar
Did you send in your PCM or did they send you a new one. I'm wondering how hard it is to
do a crankcase variation relearn with out a scan tool and yes I did receive my TVS with
the stock pulley and I the 2.9 I ordered was not in the box.
Old Oct 7, 2010 | 10:40 PM
yea im still waiting on my 2.8, they told me i should have it this week but tomorrow is friday and i havent seen it yet
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
