tvs max rpm
tvs max rpm
im sure this has been asked a million times but ive searched and cant find the answer.at what pulley size do you hit the max rpm of the tvs.i went through 3 m62 blowers from running 2.6 and 2.5 pulleys.i would like to get more out of the tvs but i dont want to be buying a new one every 30k miles. so which pulley puts it at or near the max rpm if im running at 7000 rmps?
In testing the max rpm they held for continuous operation was 18k. The blower saw upwards of 22k in brief testing with no issue.
2.5" is the smallest you would want to run. Not becuase of the blower.
Crank Pulley / SC Pulley = Pulley Ratio
Pulley Ratio * RPM = SC RPM
Crank Pulley = 6" (or so my searching has found)
SC Pulley = 2.5" (let's assume the smallest pulley made)
RPM = 7000 and 8000 (we'll test both)
6" / 2.5" = 2.4
2.4 * 7,000 RPM = 16,800 RPM
6" / 2.5" = 2.4
2.4 * 8,000 RPM = 19,200 RPM
6" / 2.5" = 2.4
6" / 2.5" = 2.4
wow i didnt know these blowers could handle that much.i just bought the 2.7 pulley for it.i want to see what kind of heat i see from this before i make a decision to go smaller.my max iat2 on an 80 degree day at wot with a 2.9 was 105.so i think it will be ok.
hahaha at this guy . my iats are 156 in fl and I'm dropping to a 2.6 next week
Damn I knew these blowers were good but I didn't think they'd be able to handle all this. That's awesome.
Just hope the engine can keep up if your going crazy with a 2.5" pulley
According to the efficiency map for the TVS 1320 the best efficiency is up to about 12K RPM. The efficiency is pretty good until you get above 16K RPM then the efficiency starts to drop alot.
I want to know how you went thru 3 m62's? I ran a 2.6 pulley for 50,000 and not a single issue. The rest of the first post has been discussed. Area is correct. You an not spin the blower high enough to cause catastrophic damage to the blower. The motor tho...
i live in south florida so it gets hotter,i just happed to be tunning on a cooler day.i dont know how i went through 3 blowers,i sprayed meth through them if that does anything to the blower.but they only lasted about 30k miles each.
Agreed. If you can get the engine to flow well you can keep the TVS in a good efficiency range all the way up to 19K.
