tvs max rpm
Old Apr 1, 2010 | 11:06 PM
freakta's Avatar
i feel dumb but what is PR and how does it effect everything?
Old Apr 1, 2010 | 11:09 PM
lsjwannabe's Avatar
Pressure ratio. (boost+14.7/14.7)
Higher it goes efficiency goes bye bye.
Old Apr 1, 2010 | 11:11 PM
Berto09ss's Avatar
Originally Posted by Area47
slowswap is close, but 100% perfect. the crank pulley is a bit bigger than 6 inches. but you get the idea.
small pulley = torque. this equals win.
agreed
Old Apr 1, 2010 | 11:28 PM
freakta's Avatar
so with my ported exhaust side of the head, i am running about 25% less boost per pulley than everyone else with the tvs. my pressure ratio is lower than most? i could potentially run more rpms on the SC and be in the efficiency range for longer? if im reading this correctly.
got any websites i could read up on to learn more
Old Apr 2, 2010 | 12:20 AM
Frew's Avatar
me likes torquez
Old Apr 2, 2010 | 08:08 AM
lsjwannabe's Avatar
That is correct, even so if you are running 20 pai your already a 2.36.
Increasing displacement is another way to lower that number.
Old Apr 2, 2010 | 09:34 AM
freakta's Avatar
im running 20psi on a 2.8,
i was looking into dropping to a 2.5 just for s&g but i dont wanna go so far out of the efficiency range that my car losses its fun edge and dies off too much up top
Old Apr 2, 2010 | 09:36 AM
lsjwannabe's Avatar
I ran a 2.5" on my car back in the testing days. For me it offered no gain in horsepower, and 2 ft/lbs.
This was also with the car on 90/10 meth on the 2.5" and pump gas on the 2.75".
Tell you what though it was funny to hit 20 psi at 2k rpms.
Old Apr 2, 2010 | 07:44 PM
Frew's Avatar
wow, 20 psi at 2k? Thats nuts.
Old Apr 2, 2010 | 10:32 PM
freakta's Avatar
well id like to see a big increase in tq.
i have no heat problems, ive got plenty of flow through the car. i will actually see a big drop in psi when i go to a 3in exhuast from what i have now...
Old Apr 2, 2010 | 11:11 PM
  #36
Area47's Avatar
Rent me! per hour
if you're only hitting 20psi with a 2.8. you are not ripping the rpms high enough.
Old Apr 3, 2010 | 12:00 AM
  #37
freakta's Avatar
^^^ that is the understatement of the year
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
Trav3480
Sep 28, 2015 02:46 PM
