TVS owners with phenolic spacers.
Old Nov 19, 2012 | 10:50 PM
Sinnah's Avatar
Hey guys I just wanted to know what you did with one of the sensors behind the TVS on the passenger side. I installed my Phenolic spacer today and the install was fine however I notice that the TVS used to hold down a sensor that sits right under the coolant hose. Now I installed the spacer the TVS sits higher and no longer holds that sensor down. I can hear it leaking air on idle and when I move it around the idle gets rough. My question is what did you guys do to combat this problem.
Old Nov 19, 2012 | 10:52 PM
Powell Race Parts's Avatar
use the bolt like it came with to secure the sensor.
Old Nov 19, 2012 | 10:55 PM
Sinnah's Avatar
It can't straighten it out to align the bolt with the sensor hole because there is not enough clearance the TVS is too big. The only way the TVS fits on is if that sensor is sitting at an angle.
Old Nov 20, 2012 | 07:55 AM
I use a bolt with a tab on mine. no phenolic spacer. but it worked just the same when i had a phenolic spacer, so not sure what you are unable to do.
Old Nov 21, 2012 | 10:20 PM
harryresh's Avatar
the spacer moves the whole manifold/blower out. It doesn't move the blower off the manifold. I had to bore the plastic bolt hole of the sensor out to twist it CW in order to clear the blower.
Old Nov 22, 2012 | 01:41 AM
Tjolley's Avatar
take the phanolic spacer off it dosnt work like every one thinks..it actually causes alot of disruption in the intake air flow..
i will be leaving mine off my 2.4 build.
Old Nov 22, 2012 | 07:46 AM
Lol this and the post above. depends on your experience I guess. Most people really like them and Distillion on OCC monitors IAT's a lot and says it works. I trust Distillion.
Old Nov 22, 2012 | 07:53 AM
BLAZIN07SS's Avatar
I'm too JDM for you
Jason being a baller with his TVS now lol
Old Nov 22, 2012 | 12:20 PM
Sinnah's Avatar
Don't know what your talking about I'm stock fool lol
You're the baller with your 700hp cobalt lol
Old Nov 22, 2012 | 12:23 PM
Sinnah's Avatar
I see what you're talking about but I can't really explain it lol It just doesn't sit on the sensor like before the spacer install.
Old Nov 22, 2012 | 01:30 PM
its really important to note. the blower sits on the manifold with four bolts. the map sensor sits in a hole on the manifold under the blower. You can remove the im and attach the blower to it and walk ten miles away from the car, the blower/map sensor/inlet manifold stays the same
lol
something has changed but its not because of the phenolic spacer
Old Nov 23, 2012 | 07:24 AM
harryresh's Avatar
lol
thats what I said earlier so I don;t know why you laughed at my post
Old Nov 23, 2012 | 08:42 PM
I didnt laugh at your post, I laughed as both your post and the post above it were good points and explained to the OP what was going on. Internetz issues obviously.
Old Dec 5, 2012 | 12:14 AM
Sinnah's Avatar
Ok I finally figured out why the hell it wasn't seated properly the f'n O ring that pushes it up so the blower sits on it came off. lol IDK where the hell that o ring went but I ordered a new MAP online hopefully I get it sometime this week.
Old Dec 5, 2012 | 10:55 PM
JapEatr's Avatar
South Central *********
New oring and modify the tab to use a bolt
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
SlowSaturn
Sep 28, 2015 11:03 AM
