tvs setup with 2.7 on stock internals
Old Jun 13, 2012 | 02:03 PM
motosledneck12's Avatar
setup on the car is vibrant 4-2-1 header, catless 3 inch downpipe, k&n CAI, magnaflow catback with no resonator, duel pass endplate, zzp stage 3 heat exchanger, and currently running tvs with 2.9 pully. i will be installing option b and phelonic intake spacer before i change to the 2.7 pully along with new head gasket and arp head stud.
will my stock internals be able to handle it? the engine has 108000 miles on it
Old Jun 13, 2012 | 02:06 PM
EXsoccer1921's Avatar
i bet that exhaust sounds loud as ****..
Old Jun 13, 2012 | 02:08 PM
zrated89's Avatar
that was similar to my mods a little different and i had a few more things than you. I would highly reccomend meth injection or E85 and u should be good to go. Also a good idea to check compression on your motor or do a leak down test to see what kind of shape shes in. No reason to do the headgasket if theres no issue with it.
Old Jun 13, 2012 | 03:32 PM
compression is good al across the board, i dont have e85 where im at and i realy dont want to go with meth i put 4,000 mile a month on the car, its a daily driver and my gas milage car.
and as far as the head gasket i thought it would be to much boost for the stock headbolts, and my headgasket is leaking a little oil.
Old Jun 13, 2012 | 03:34 PM
mrbelvedere's Avatar
why dont you go read the tvs sticky
how much boost is to much for our engine in stock form? i am running about 20psi with the 2.9 and in the winter it hits 24psi. i just dont want to over boost it when winter comes.
and the car also has 80# injectors and a breather setup
Old Jun 13, 2012 | 04:21 PM
Bluelightning's Avatar
Got Bewst?
You only pump meth when you have your foot into it. It won't affect your daily driving. And a good idea to run if you are going to pulley down that far.
Old Jun 13, 2012 | 05:09 PM
i understand that, but its another thing to go wrong, and if something does go bad and the meth doesnt work im tuned for it and its an entire day to drive to get the car tuned. and then i have to buy methnol. its just convenient to not go with it. and im already worried about the reliability without meth on a stock motor.
its just a piece of mind thing for me not to have meth, although i would love to have it. if my car is down it costs me an extra $20 a day to drive my truck to work.
you wont find a guy with worse luck then me when it comes to stuff like that.
Old Jun 13, 2012 | 05:10 PM
dont have time to read through all the pages. only time i have access to internet is while im at work and i shouldnt be on here while im at work.
Old Jun 13, 2012 | 05:43 PM
Got Bewst?
Pullying down probably isn't a wise decision then IMO
Old Jun 14, 2012 | 08:56 AM
so none out there is running a 2.7 tvs without meth? what about 2.8?
Old Jun 14, 2012 | 09:52 AM
carstedt's Avatar
ull b ok if u get a straight tune and dont beat the **** outta ur car..but meth is highly reccommended
Old Jun 14, 2012 | 10:04 AM
07LSJ's Avatar
im sure some ppl are running a 2.7" pulley on their tvs without meth, but i bet they made sure that the motor was in healthy conditions to handle it. also probably with less miles than your car. if its ur dd and you want reliability just stick to the 2.9.
Old Jun 14, 2012 | 10:15 AM
zrated89's Avatar
for the amount of timing youll have to remove from the tune going to the 2.7 gains will be hardly anything and will put more strain on your motor. If youre not gonna have the octane stick with the 2.9. It doesnt sound like youre ready to do whats nesscesary and safe for your motor
Old Jun 14, 2012 | 10:21 AM
Staged07SS's Avatar
Administrator
Administrator
Listen to this ^
Old Jun 14, 2012 | 12:03 PM
agree with those two guys ^^
Old Jun 14, 2012 | 12:29 PM
so if i did run methanol i would be safe for the 2.7 but do you think the motor would handle the 2.7 + meth or would i be better off staying at 2.9 if i where to use meth?
i realy appreciate all the input guys. thanks
Old Jun 14, 2012 | 12:32 PM
Got Bewst?
Your motor will be able to handle the 2.7" no problem
Old Jun 14, 2012 | 12:43 PM
ebristol's Avatar
Listen to this ^
Is this where I sign up for the circle jerk party?
Old Jun 14, 2012 | 12:44 PM
TStone's Avatar
You COULD throw a 2.6 on it and be fine.. with methanol or E of course.. but at the end of the day, the tune is what's gonna keep your motor together or separate it /:
ahaahha
Old Jun 14, 2012 | 04:01 PM
ahaahha
the car will be profecialy tuned by shane at db performance
so would i be better off buying a meth kit instead of buying an option b and a phenolic intake spacer and then go for the 2.7
Old Jun 14, 2012 | 04:19 PM
Got Bewst?
Most definitely. The phenolic spacer is a real nice piece but not crucial to have. I would run atleast a 10gph nozzle with your set up.
Old Jun 14, 2012 | 04:47 PM
TStone's Avatar
Honestly.. You seem pretty worried about something happening to your car..
(not that everyone else isn't)
sooo.. why not buy everything that'll help it? Meth, Phenolic spacer, & dual pass..
Your car will thank you in the end.
Old Jun 14, 2012 | 05:33 PM
because im not made of money
Old Jun 14, 2012 | 05:36 PM
TStone's Avatar
Okay well get everything first, and then save for a TVS.
