tvs setup questions
Old Oct 30, 2010 | 12:07 PM
Area47's Avatar
Rent me! per hour
Originally Posted by Darkmanx
stop fudging your fudging numbers to try to be higer than me
Don b h8n y0. I did it, i wouldnt drive it on that level of insanity though. You were chasing my numbers doucher. I just happen to raise the bar more.
Old Oct 30, 2010 | 01:01 PM
freakta's Avatar
^^^^ hahahaha
tvs smaller pulley, 3in exhaust, cooling mods, great tune... but 400whp is insane for these little cars. be sure you want it
Old Oct 30, 2010 | 05:46 PM
SatanzSS/SC's Avatar
Originally Posted by freakta
^^^^ hahahaha
id like to make 400 hp but when it comes down to it, its gonna take way to much money to get it to that point. id like to make somewhere in between 350-400 hp without blowin up my car! would the zzp stage 3 h/e be good enough to run in my car if its puttin down those types of numbers?
Old Oct 30, 2010 | 05:56 PM
Spins All Day's Avatar
Originally Posted by SatanzSS/SC
im wanting to make big power. ive been looking into getting a tvs supercharger. my questions are what other supporting mods are 100% needed? i know id need a header, dp, exhaust, bigger tb and of course a tune. but what else would i need? tvs guys please chime in. any info would be greatly appreciated. thanks!
Save your money and buy a turbo kit or put the money down on a Turbo Cobalt.
A TVS was cool in 2007/2008 when Turbo Cobalts were brand new and everyone was sick of the M62.
If you do decide to go with a TVS you need a heat exchanger and the dual pass intercooler, as well as a great tune.
400 HP with a TVS, lol the only way you will make 400 WHP on that LSJ is with a Forged motor cams a ported head and a GT30R (which is a turbo)
Last edited by Spins All Day; Oct 30, 2010 at 05:57 PM. Reason: Automerged Doublepost
Old Oct 30, 2010 | 06:04 PM
jsscriado's Avatar
Why don't you go turbo?
Old Oct 30, 2010 | 06:07 PM
InfraRedline's Avatar
An LSJ can run 400whp stock motor stock head on a snail all day long, but thats besides the point
Old Oct 30, 2010 | 06:09 PM
Darkmanx's Avatar
oh no you didnt. 2 snaps.
Old Oct 31, 2010 | 01:38 AM
Area47's Avatar
Rent me! per hour
you don't need a dual pass. people need to get over this ****. why is it, the fastest tvs car, and the highest whp tvs car had dick for cooling mods?
because we made power.
you can do 400whp on a stock short block lsj and the tvs. it is far from easy, but can be done. a cam swap on my old car would have done it.
Old Oct 31, 2010 | 07:11 AM
how much would it cost to go turbo? im new to the world of forced induction so you can understand why i may have so many questions! as far as what ive seen, going turbo would cost me so much more then to go with a tvs. please correct me if im wrong. dont get me wrong, id love to go turbo because ive heard of power potential with turbo setups but they're just do expensive.
Old Oct 31, 2010 | 08:50 AM
WSFrazier's Avatar
If you plan on actually racing the car at a track and not be a Fast/Furious street racer like 99% of the kids on here... You will appreciate the TVS more.
Unless you really want to have that high peak number from a random spike on a dyno that you will never see again.
Old Oct 31, 2010 | 08:53 AM
  #36
Darkmanx's Avatar
Turbolag actually benefits this car it helps get traction a turbo would cost u 1500-4000 depend on your setup. Tvs gonna be more to maximize the benefits
Old Oct 31, 2010 | 08:55 AM
  #37
WSFrazier's Avatar
No, tires get the car traction...
Old Oct 31, 2010 | 09:06 AM
  #38
Darkmanx's Avatar
^^^^^^^nig your **** slow ain't nobody listening to u
Old Oct 31, 2010 | 09:07 AM
  #39
WSFrazier's Avatar
Just trying to get a few pokes in at the slow "big" turbo guys.
Old Oct 31, 2010 | 09:49 AM
  #40
Darkmanx's Avatar
I'm sorry, come drop.a cam in the g8 for me.
Old Oct 31, 2010 | 10:16 AM
  #41
selfinfliction's Avatar
buy turbo kit instead, more power @ same costs
Old Oct 31, 2010 | 10:19 AM
  #42
roderick's Avatar
After having both the TVS and a Turbo I would say go turbo. I have a billet 5857 turbo it spools to 18psi by 3500. There is no turbo lag it gets up and moves. I dynoed 360hp 317tq with very low compression in cly 4. Turbo kit you are looking between 2500 - 4000$ on zzps kit you can make between 350-500hp depending on what setup you go with. Basically you can do get 400hp with a turbo kit for about the same or less money and have a safer setup.
Random spike no. Go look at my dyno numbers for 360 or any of my ten dyno pulls I did. Power was tuned to keep a nice hp and tq curve. The tvs is also going to generate more heat and cause more problems. I was running 145 degrees with e85 after one pull in 4th gear. I did 5 dyno pulls in 4th gear and the highest my temps got was 115.
Old Oct 31, 2010 | 11:41 AM
  #43
BlackMagic's Avatar
I want to see proof of comparable whp turbo car vs tvs car and see who makes the better times at the track. personally I don't rely on the little number on the computer to tell me how fast my car is... sweet you put down 400 with your turbo... why are you still in the 13s? lol I guess my point is I would rather be faster any day than have the dyno tell me I peaked at a higher number.
Old Oct 31, 2010 | 11:45 AM
  #44
BlackMagic's Avatar
how to build a 400whp tvs lsj.
i did 380whp on mine {yes darky, 380}
3inch intake
tvs
2.6 pulley
80, or 98lb injectors
return system
255 fuel pump
surge tank
bosch 044 pump
SC specific cams
supertech 78lb valve spring kit
ported head, intake and exhaust side
neutral balance shafts
1 3/4 or larger primary header with a 3inch collector. burns stainless or equivalent
3 inch exhaust
3 in down pipe
bad ass tune
e85, or 110 octane fuel
a good heat exchanger. griffen core.
for added measure to hit it. 10.0:1 - 10.5:1 C/R.
you might be able to do it on stock compression
where did you get the 98's?
Old Oct 31, 2010 | 01:12 PM
  #45
WSFrazier's Avatar
Lol, you are missing the point.. and proving my own point entirely.
Old Oct 31, 2010 | 01:15 PM
  #46
WSFrazier's Avatar
+1
Nothing like seeing 400+ turbo cars run 13s and my little 320 machine running low 12s.
All people care about with these cars are peak numbers on a computer monitor.
Old Oct 31, 2010 | 02:02 PM
  #47
+1
there's more to a fast time than power, and much more to it than just power band. 4-5 years ago i had a gtk450 system on my cobalt and was running 11.2x at only 400whp, that was with a 4000-4200 spool.
isn't zzp's car turned down to 500 something and running 10's? and that thing has a monster turbo on it, no telling where it even spools at. so 400whp runs slower than your car, but 500whp runs 2 seconds faster? IT'S THE SETUP ON THE CAR and not some magical supercharger powerband
hell, i make over 200wtq at 2500rpm with a turbo and that's what gets the car moving
Old Oct 31, 2010 | 02:16 PM
  #48
WSFrazier's Avatar
I should of worded my statment better. A properly setup Turbo car could and should do better at track. Such as ZZP.
Was trying to poke fun at the big turbo children that dyno their car in 5th and only do 80mph rolls.
I guess I am the only one that finds it funny the only turbo swap LSJ on forum that actually runs what their power dictates is a shop car. Yet they all claim how much faster their snail is than any blower car.
Old Oct 31, 2010 | 02:19 PM
  #49
BlackMagic's Avatar
+1
yup no one understands peak numbers don't win races. and as selfinfliction said a properly set up car its the key no just a monster turbo and 100000hp
Old Oct 31, 2010 | 04:10 PM
  #50
mine will be 11.5x minimum in spring, and that has nothing to do with any shop around other than our garage, and it'll be 400whp or less. ran a 12.24 in september on 23psi @ 360whp
that's on a completely stock block and head
