UEGO in new ZZP pillar
Old Apr 7, 2009 | 09:18 PM
KillinKrullin's Avatar
ok guys so can i get some pointers or pics on how you guys have youre AEM UEGO wideband gauge installed on your new ZZP 3 gauge pillar?
thanks a whole bunch
Old Apr 7, 2009 | 09:23 PM
SS/SCking's Avatar
I think it looks awful in the pillar due to the size of the bezel. look in to a column pod or the gauge surround pods....To put in the pillar you have to make the hole slightly bigger . Use sand paper
Old Apr 7, 2009 | 09:38 PM
Red05SS/SC's Avatar
mine wasn't even clocked right with the holes that they have built into the back of the gauge pod. I just took some snips cut their plastic and then cut the AEM hold down in half and secured it with that. So it looks good now. No you don't need to sand with this one its made for the uego gauge.
Old Apr 7, 2009 | 10:45 PM
HunterKiller89's Avatar
I had to demel out the pillar a bit to make it fit, but i have the CA one. Same deal though...it looks nice, but isnt a direct plug and play. Be careful you dont dremel anything you dont have to either
Old Apr 7, 2009 | 10:50 PM
anyone whohas dremmelled the secondary holes out for a UEGO have any close pics of the fitment?
thanks for the info guys thats what i was afraid of. i didnt feel like cutting anything just yet so i extended the stock boost gauge to the middle hole and slapped the UEGO in the bottom..
oh btw those holes are "clocked" properly for the stock gauge. For the UEGO i just drilled another hole so i can put the stock one back down there once im brave enough and have seen others put it up top.
thanks again guys!
Old Apr 7, 2009 | 11:19 PM
cobaltss86's Avatar
i have a 2 gauge pillar and i dremeled out alot of the pillar where the ring screws on the gauge so the back of the pillar is and i have an aftermarket boost gauge i had to do the same on it
Old Apr 7, 2009 | 11:23 PM
b_faulk75's Avatar
I drilled the secondary holes out in the bottom to put in my innovate boost gauge. One thing i noticed about this gauge pod is the indent for the gauges is small in them, it's hard to get the gauges to sit flush...
Old Apr 7, 2009 | 11:29 PM
StockSS's Avatar
Old Apr 7, 2009 | 11:56 PM
auggie_ss_phx's Avatar
i have the C.A one but i put mine on the top.i just had to dremel out a lil bit to fit
DarrenGC
Dec 24, 2021 01:55 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
