underdrive pulley
Old Sep 26, 2005 | 10:48 AM
geedog66's Avatar
underdrive pulley
i was woundering if the pulley from the 2.2 is the same as the 2.0 sc???
Old Sep 26, 2005 | 12:27 PM
DanM's Avatar
If you mean a smaller diameter crank pulley, you don't want that on an SS/SC. It'll do more harm than good. Here's why:
#1 UD crank pulley will drive the supercharger slower. That'll hurt power.
#2 Most of the gains from a UD pulley usually come from driving the water pump slower. In the case of the LSJ, the water pump is not driven off that belt, so a smaller pulley won't help you there. All it'll do is drive the alternator and AC compressor slower. Alternator won't really give you much gain. Driving the AC compressor slower will help out a touch (only when the AC is on). But either way, it won't make up for what you'll lose in driving the SC slower.
Old Sep 26, 2005 | 01:57 PM
geedog66's Avatar
not a smaller diameter a lighter pulley instead???
Old Sep 26, 2005 | 05:20 PM
DanM's Avatar
You don't want smaller diameter on a supercharged vehicle. Smaller diameter will hurt your performance whether it's lighter or not.
If it were the SAME diameter so as not to underdrive the supercharger, but a couple pounds lighter, then it couldn't hurt. But I really doubt it'd be worth your time to bother with it.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
cw383
Sep 30, 2015 12:41 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
