Underdrive Pulley for Cobalt SS
Old Aug 17, 2005 | 11:30 PM
3fo893013L's Avatar
While everyone is eager to get basic bolt ons to increase HP & Torque with intakes, smaller supercharger pulleys and exhaust systems I think the most overlooked item that most cars can also benefit is also the least looked at item for this car. An underdrive pulley. Yes, I know the ecotec 2.0L is a free flowing motor and rev happy, the one thing that it can benefit from after basic bolt ons with this is the U/D pulley.
From what I have heard it can also free up an extra 10HP or more (Forced induction only), with this in mind, has any vendor even taken into consideration getting some protypes on the board? I was like looking at the accesories pulley today and damn that thing is big. Def need something smaller in there.
Does the 2.2L ecotec already have one? (From the Cavailer, Sunfire, Grand AM days) and if so.. is the bolt pattern the same where we can just slap it on the 2.0L? or do we need something different all together? That is the cheapest but also most effective mod you can install on a car besides what I listed above. Are we overlooking this?
-Mike
Old Aug 17, 2005 | 11:50 PM
Jmc007's Avatar
I think the #88958631 Billet Crankshaft Pulley on the following page http://www.gmgoodwrench.com/perfpart...284&section=pp is the pulley for the 2.2 Ecotec, but i am not sure yet. I wrote today to GMPP to know if it can fit on a 2.0 SS/SC.
Old Aug 18, 2005 | 01:03 AM
Vita's Avatar
you want to be carefull, as running an underdrive pulley will change the speed at which the blower spins if i'm not mistaken. somebody please correct me if i'm wrong.
i think the best bet would be to get lighter pulleys, that way you still have the option of running pulley upgrade kits as they become available.
Old Aug 18, 2005 | 01:42 AM
riz906's Avatar
shouldnt change it that much,
but is that pulley for a 2.0 or 2.2 that is the question.
some stuff doesnt work.
Old Aug 18, 2005 | 08:51 AM
3fo893013L's Avatar
according to one of the pages I visited for the pulley it's suppose to spin more freely , not drag more. I would think this would be an advantage for the blower with less hesistation.
Old Aug 18, 2005 | 09:07 AM
vB00STw's Avatar
so if you put on a smaller diameter pulley, you'll have more HP?
Old Aug 18, 2005 | 09:16 AM
3fo893013L's Avatar
bigger pulleys cause more drag, especially if you runs accessories such as a/c. The purpose of it is to create less drag, allow it to spin more freely and free up extra HP without comprimising the accessories.
Old Aug 18, 2005 | 06:42 PM
Jmc007's Avatar
Here is the answer of GMPP ...
Thank you for visiting the Goodwrench website.
Mr. xxx, thank you for your inquiry regarding pulley, part number
88958631, and whether it will fit on the 2005 Chevy Cobalt SS 2.0. We
searched our system, but unfortunately were not able to find this
information. Our best suggestion is that you contact your nearest GM
Performance Parts dealership or contact GM Canada Customer Care Centre at
1-822-263-3777 where you can speak with someone directly. The Customer
Care Centre has access to more extensive technical options and may be able
to help you further.
There is a Performance Parts dealership in Piedmont, St.Laurent and
Ste-Therese, Quebec. Sorry we were not able to help you more.
Regards,
Goodwrench Internet Response Team
Thinking of that, the pulley should be for the 2.2, because a smaller pulley would make the blower turn slower ...
Old Aug 19, 2005 | 12:21 AM
Vita's Avatar
running a smaller pulley causes the accessories to spin slower, taking less power from the belt system (the "drag")
but changing the size of the pulley also affects the pulley ratio of the S/C if it's in the same belt system. a good way to see this would be to look at the diagram under the hood.
i'm not saying it would be bad, but it COULD alter the pulley ratio of the S/C. and with the LSJ being so sensitive to mods and wanting to go into limp mode, running a pulley upgrade kit designed for a certain airflow might be hindered by a minor mod like an underdrive pulley. contacting PSI-FI about this would be the best way, as they're the only company that's got something available (if only for local guys while they work things out).
all i know is that it's taken them a while to work things out without the car going into limp mode. instead of spending 100 on a pulley (or whatever it'll be). i'd wait and spend 500 on their kit and get MUCH more power reliably. they'll know best though. should be fine on a stock car, it's just that later down the line you might end up having to get rid of it (don't see the point of getting an underdrive pulley if you don't plan to take things further).
ok i'm done...
Old Aug 19, 2005 | 02:39 AM
JapEatr's Avatar
South Central *********
these are usually crank pulleys, not the SC pullleys
also i would be weary of some kits with water pump/ alternator pulleys
Old Nov 9, 2005 | 01:00 PM
jymontoya's Avatar
Just to bring the discussion back from the dead.... A lightweight OVERDRIVE pulley is what you would want. This would increase boost by a few %. Pretty common for the guys with the Mini's... http://www.altaminiperformance.com/p...ankpulley.html
Old Nov 9, 2005 | 01:10 PM
3fo893013L's Avatar
Good example. I am sure we will see something designed in the future for these motors.
Old Nov 9, 2005 | 02:03 PM
VaMP's Avatar
Why would you want an underdrive pulley system on a car that is dependent on how many RPM's the crank is pushing? Sure you might gain 10HP from a pulley swap on a 2.2L - but this is a motor with a supercharger that is driven off the pulley system. The whole point of going with a smaller pulley for the supercharger is to increase the rotor RPM's thus creating more CFM @ a certain RPM. But lets say you ignore all this, and buy one and install it. Your supercharger spins at a slower rate, thus creating a loss of horsepower. So you try and match it with a smaller supercharger pulley, but you're only going to break even if even that. Then you realize that this was just a waste of money and you could of better spent it on a piggy back system or a stripper.
None of the GM Racing Cobalt's have this done, overdrive or underdrive, and there's a reason for it. It's NOT worth the money.
Old Nov 9, 2005 | 02:05 PM
theBLUEone's Avatar
I know RSM Racing has a lightened crank pulley (stock size just lighter) for the 2.2L ECO I had one on my 03' Sunfire...I wonder if it would fit but I no longer have the car nor the pulley..
Old Nov 9, 2005 | 02:18 PM
redd214's Avatar
i have the rsm pulley u speak of on my car. it will not fit the lsj. l61 has 5 ribs, lsj has 6. if u gus sparked enuff interest im sure theyd make em for yall as well.
Old Nov 9, 2005 | 03:08 PM
zinner's Avatar
Moderator Alumni
except a smaller crank pulley means the supercharger would spin slower too... Pretty much would shoot you in the foot.
Old Nov 9, 2005 | 03:22 PM
theBLUEone's Avatar
The RSM crank pulley, if they were to make one for the LSJ, it would be the same size as stock just lighter so the s/c wouldn't spin at a slower rate...
Old Nov 9, 2005 | 03:40 PM
xskier874's Avatar
IMO if you make the pulley smaller its gonna slow down the belt causing the supercharge to spin slower.
you may gain alittle power but i doubt it will be more than 1 or 2 without other pulleys.
Old Nov 9, 2005 | 03:56 PM
redd214's Avatar
the rsm crank pulley is stock sized. its made out of aluminum to shave off a few ounces. the car revs a lil faster with it. not a significant gain but just a piece of the puzzle
Old Nov 9, 2005 | 04:07 PM
Drewfu$'s Avatar
Like said above, if you change the size of the crank, you'll throw off the superhcarger pulley. Make the crank smaller, you'll have to make the blower pulley smaller too. But you guys are already pushing the limits as to how small of a pulley will fit the blower.
If anything, make it lighter.
Old Nov 9, 2005 | 04:12 PM
Leafy's Avatar
Good Advise.
Old Nov 9, 2005 | 04:19 PM
Psycho's Avatar
Do you sell pot
Old Nov 9, 2005 | 04:21 PM
R33P3R007's Avatar
360 L337 User
Originally Posted by Psycho
Do you sell pot
Old Nov 9, 2005 | 05:06 PM
SilverSS/SC's Avatar
Add to that the nice dim lights and dash lights at idle because the alternator is slowed down . Ive never been a fan of underdrive pulleys . To many possible issues with voltage and cooling for the miniscule gain in power . jmo .
Old Nov 9, 2005 | 06:11 PM
phxSS's Avatar
smaller UDP will make the blower spin slower= less power
