Upgraded Heat Exchanger question
I like the cx racing h/e. I should go nice with my single pass IM.
did you get my email address?
Close. Filling the cx racing h/e at the cap would be the quickest way to get started purging the system. But the h/e cap is not at the hightest point in the cooling system so you would still need to bleed out the system just like the cobra h/e.
This brings up another good question.
For guys running the CX Racing H/E, do you cap off the H/E overflow port or do you tie it into the system using an overflow tank or something like that?
Last edited by qwikredline; Apr 14, 2008 at 10:37 PM. Reason: Automerged Doublepost
I was thinking (dangerous) that I might do a small production run of laminova inlet kits set up for single pass on an exchange basis, but its a lot of work and work costs money so maybe its a dumb idea...the thought and testing that goes into this stuff is silly and its hard to make a buck on it...even 10% margins are hard to get to.
and then you gotta buy a reservoir, thats what 30-40 bucks, and if you did a dual pass end plate thats 260 bucks, then there are brackets and hoses, Y and T fittings, restrictor and labour to install proper fabrication and stainless radiator screeds
dont even think about using tool time strapping and sheet metal screws
The single pass Laminova takes some extensive TIG welding thats not an easy, cheap task; the plumbing is such a pain I ran rubber moulding along the front tie bar i cut my fingers so many times on the redline... so now that I have written this I have decided it that it isnot a good idea... good luck ebristol, nice part of the country you live in. Wisconsin: Kenseth. Kulwicki. Favre. Milwaukee mile...Road America....Harley Davidson....whats not to like...
The single pass Laminova takes some extensive TIG welding thats not an easy, cheap task; the plumbing is such a pain I ran rubber moulding along the front tie bar i cut my fingers so many times on the redline... so now that I have written this I have decided it that it isnot a good idea... good luck ebristol, nice part of the country you live in. Wisconsin: Kenseth. Kulwicki. Favre. Milwaukee mile...Road America....Harley Davidson....whats not to like...I was thinking (dangerous) that I might do a small production run of laminova inlet kits set up for single pass on an exchange basis, but its a lot of work and work costs money so maybe its a dumb idea...the thought and testing that goes into this stuff is silly and its hard to make a buck on it...even 10% margins are hard to get to.
Yeah its a lot of work and no one will appreaciate it and they wont want to pay more then $1 over the cost of parts.
i bolted it to the bottom of that long big metal bumper piece when the bumper is off. then the other side of the L bracket screwed to the BACK of the side of the h/e so you wont see it when you look at it, just little screws that go through a little. fills up the entire bumper opening, looks real badass
Im having one being custom made at the rad shop right now, slightly bigger then the cx racing on with no filler cap and two mounting tabs perfect for the cobalt with sid inlets for easy hose routing. if anyone is interested he wants to start selling em, pm me, if i get intrest ill become a vendor
i pick mine up at 5 tonight to install inplace of my cobra.
just let me say it again, this will have mounting plates included already welded to the unit, on top to mount to the bumper support not on the sides, all you will need to do is drill 2 holes in your bumper support and drive away. this is much wider then the cx too, it fills the whole front grille and it is slightly deeper core too, all together more surface area for cooling
you will not need to remove the bumper to install it either
Last edited by BOOSSTED 06; Apr 15, 2008 at 02:08 PM. Reason: Automerged Doublepost
