upgrades questions? ???
Old Jun 7, 2013 | 08:41 AM
James200157's Avatar
My car already has down pipe, exhause, no cat, intake, 2.8 pully, 50 injectors
I want to upgrade the pully to a 2.6 and the injectors to e85 and add dual bypass, intercooloer and get it tuned . 93 gas
Wat im asking is that ok to do or do I need to do other things to not have problems?
Please need suggestions ...its a DD car im only wanting about 310 to 350 out of it .and dont want to convert to turbo
Old Jun 7, 2013 | 09:06 AM
dcrep06's Avatar
you could also do the TVS blower, seen a lot of people running those numbers with that swap.
Old Jun 7, 2013 | 09:16 AM
"the injectors to e85".... "93 gas"
i think you are confused. it would be good to run e-85 gas, through 80# injectors. dual pass and a second heat exchanger will help (dual pass with cooldown times, heat exchanger with keeping iats down)
most everyone says 2.7" is the smallest pulley you should run before the blower just causes too much heat.
with all that you may be close to 300 (280ish wheel)
throw a tvs on to hit those numbers easier, or build the top end!
Old Jun 7, 2013 | 09:54 AM
Wats tvs?
Old Jun 7, 2013 | 10:09 AM
dcrep06's Avatar
better SC than the m62 lol
HARROP - Harrop TVS Supercharger #HTV1320-LSJ
Old Jun 7, 2013 | 10:23 AM
Oh gotcha well **** how much do u get from bolting on that sc
Old Jun 7, 2013 | 10:24 AM
mrbelvedere's Avatar
search button it works use it
https://www.cobaltss.net/forums/2-0l...-guide-217195/
https://www.cobaltss.net/forums/adva...ow-faq-184037/
Old Jun 7, 2013 | 10:26 AM
dcrep06's Avatar
https://www.cobaltss.net/forums/2-0l...thread-275327/
read on my friend. not sure exactly numbers but all depends on tune.
those too lol.
Staged07SS's Avatar
Administrator
Administrator
Lots of good info in the links posted above ^
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
