upped rev limit on gm stage2?
Old Sep 29, 2006 | 09:28 PM
Smooth23's Avatar
Okay, 2 friends of mine have SS's, one has a stage 2 and the other doesn't. I know the one without redlines at 6500 and the one with redlines at 7200(maybe 7400?) . From the reading I've done here I've seen posts that say a stage 2 gm flash will not up the rev limit. He does however have a gm stage 2, installed by another mechanic. Did he void the crap outta his warrenty with the upped rev or what?
Old Sep 29, 2006 | 09:42 PM
Sicklyscott's Avatar
GM stage 2 redline is set at 7000 rpms
Old Sep 29, 2006 | 09:46 PM
BriantheLion26's Avatar
The GM Stage 2 kit does not void warrenty. It is through GM. It does raise the rev limiter from 6500 rpm - 7000 rpm.
Old Sep 29, 2006 | 09:47 PM
s2kricer17's Avatar
gm stage 2= 7000
hptuners= 7000+
im currently at 7400
Old Sep 29, 2006 | 09:53 PM
s2kricer17's Avatar
i thought if you bought the stage 2 that it voids your warranty... but keep the warranty for the GMstage 2 parts?
Old Sep 29, 2006 | 10:00 PM
StinkBOMB's Avatar
The search button will cure all your questions about GM Stage 2, hell there's a sticky in the 2.0 performance section. These questions have been answered a million times over. Read the sticky.
Old Sep 29, 2006 | 10:04 PM
rollingboostedss's Avatar
just a quick fyi around 6800 the valves start to float. but hey its your engine
Old Sep 29, 2006 | 10:07 PM
StinkBOMB's Avatar
The allmighty GMPP division has set the rev limiter at 7000, so apparently GM doesn't think it's a problem. Yes, I saw the post where the GM tech came and stated that the valves do start to float around 6800, but GM doesn't car so I wouldn't either.
Old Sep 29, 2006 | 10:09 PM
all your power is gone after 6500 anyways so why run the car to 7000 yeah you'll get some more mph. I just don't see the point in putting more stress on the engine then you half to. just my two cents
Old Sep 29, 2006 | 10:21 PM
Doc's Avatar
Doc
um....by power do you mean torque..?? or do you mean horsepower..??
the torque not building after 6500 might be close, but horsepower builds until redline.
I won't even touch the valves floating at 6800....
Old Sep 29, 2006 | 10:28 PM
Smooth23's Avatar
I dont even have a cobalt yet, and I can guarantee you after 6500 you get alot of power. When the one friend got his stage2 installed he kept getting beat by the guy without. So we go for a few runs to analyse his problem, he was shifting at 6400 still, shifting at 7000 made it a rape... if you didn't get power after 6500 gm wouldn't up the redline.
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
