Urgent !! Please Help !!
Old Sep 28, 2006 | 07:20 PM
07Cobalt's Avatar
I am in the process of upgrading my headlight bulbs with the Noyka 7000K bulbs. I've removed the two clips but don't know what to do next. Do I have to remove the front bumper? I need your help. Pictures would be nice. Thanks, guys.
Old Sep 28, 2006 | 07:38 PM
Xenozx's Avatar
nah bumper stays. If you just replacing bulbs? Fogs or Headlights. Ive done both and never removed the bumper.
If your trying to get to the headlight its super easy, 2 bolts on each side. Just take em out, remove all the clips hear there and the headlight housing pulls right out. Unscrew the bulb holder pop the new one in (make sure you dont touch the bult w/ your fingers) and reverse. If you want to get to the Fogs, its a little harder but can be doen w/ out removing the bumper.
Just take the headlight housing out. Then theres a plastic thing under that thats held in by 2 more bolts. Take that out, and if you are of normal build (not 300+ lbs) you should be able to reach your arm in and unscrew the stock bulb, and then screw in the new one.
you have to do like 1/4 turn to get the bulb out. make sure you put the new one in on the same angle/position you took the original out. Its not hard, once you do it you will understand
banabanu
Sep 18, 2014 10:54 PM
joe_589
Dec 22, 2010 12:08 PM
Koenreich
Nov 4, 2010 05:37 PM
Jameshs
Jul 27, 2009 08:24 AM
