Valvetrain
Old Jun 28, 2008 | 02:20 PM
ls1fbody's Avatar
Haz l33t wheelz.
Valvetrain
ok, what are the specs on our valve springs/retainers? i want to uprade mine, because when i eventually get a tune and raise my rev limiter, i don't want to chance valve-float.
thanks guys!
Old Jun 28, 2008 | 02:25 PM
Raven SS's Avatar
my hood..
Old Jun 28, 2008 | 02:29 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Stock valves are said to Float at like 7200rpm.
Old Jun 28, 2008 | 02:30 PM
Zach06CobaltSC's Avatar
If the stock valves are said to float at 7200 rpms, is it "dangerous" to take it to 7000k rpms on the dyno?
Edit: I have the gm stage 2 tune, so I can hit 7k rpms. Roughly.
Old Jun 28, 2008 | 02:33 PM
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by Raven SS
my hood..
haha, im doing research man! haha. nothing is being bought until October/December time frame, just want to get as much info as i can, so i don't f things up.
that's what i thought, thats about where i want to set mine, 7200/7500 and i don't want to destroy stuff. doesn't stage 3 allow you to go all the way to 8000?
Old Jun 28, 2008 | 02:35 PM
Altiery54's Avatar
stage 3 allows u to adjust ur rev limiter to anywhere between 7k-8k i believe it allows u to raise it by 250 rpm incriments.
what happens when u float a valve?
Old Jun 28, 2008 | 02:37 PM
ls1fbody's Avatar
Haz l33t wheelz.
bad bad things.
Old Jun 28, 2008 | 02:39 PM
Raven SS's Avatar
people have taken it to 7500 without aftermarket valve train and without neutral shafts
Old Jun 28, 2008 | 02:42 PM
o3nisoaso3's Avatar
basically it doesnt stay on the cam lobe (stays open) and pretty much lose power
Old Jun 28, 2008 | 02:43 PM
ls1fbody's Avatar
Haz l33t wheelz.
i'd rather be on the safe side. anyone know?
Old Jun 28, 2008 | 02:47 PM
mrniceguy8211's Avatar
I rev mine out to 7200-7300k all the time, I have had no problems. My limiter is set at 7500k but yes I can set it to 8000k with the stage 3.
Old Jun 28, 2008 | 02:51 PM
No... you will have absolutely no problems with valves in that sense.
Sounds good.
Which is why I said "Stock valves are SAID to Float at like 7200rpm."
Stock pistons are also SAID to go out at like 260-280hp...
That's been smashed quite a few times.
7200rpm's is where GM says they have potential to float.
Just upgrade them and take that bitch to 8k.
Old Jun 28, 2008 | 02:56 PM
ls1fbody's Avatar
Haz l33t wheelz.
well, im looking for what size/spring rate or whatever they measure valve springs by. i don't know to much about their technical specs, just what they do, haha
Old Jun 28, 2008 | 02:57 PM
Buy the biggest, most expensive ones then...
Old Jun 28, 2008 | 03:02 PM
ls1fbody's Avatar
Haz l33t wheelz.
haha. no thanks.
Old Jun 28, 2008 | 03:34 PM
I am making 270hp to the wheels...do you think i should upgrade my stock pistons to the diamond pistons everyone uses, and with doing so also upgrade the springs even though i won't be taking my car over 7k rpm's?
Is 270whp really to much for the stock pistons....if so...thats sad.
also - if the stock pistons go at around 260-280...why is the zzp twin kit making 445hp and still pulling strong?
Last edited by Zach06CobaltSC; Jun 28, 2008 at 03:34 PM. Reason: Automerged Doublepost
Old Jun 28, 2008 | 03:36 PM
ls1fbody's Avatar
Haz l33t wheelz.
thats just what GM suggests. raven built his entire motor and it still blew. ZZP's car won't last long like that on stock internals.
Old Jun 28, 2008 | 03:59 PM
You fail.
GM SAYS that the stock pistons won't hold more than 300hp (not WHP... but BHP). Obviously there are quite a few people making WELL over than.
Your best bet is to switch them out, just to be safe... if you plan on making more HP eventually.
Its all in the tune really.
Old Jun 28, 2008 | 04:38 PM
currently i have the gm stage 2 tune, but i will be getting an actual tune sometime in july when my tuner gets back.
I do plan on making more power, what do you suggest I upgrade to stay "safe"?
Sharkey
May 4, 2008 01:59 AM
JBP
JBodyPerformance
19
Mar 7, 2008 10:33 PM
CobaltDemon
Oct 23, 2007 01:32 PM
XM15
Apr 4, 2007 12:13 PM
