Valvetrain
Originally Posted by Bad06SS
It's probably not going to be too cheap. The valve springs on these motor's are a fairly tough job. Plus, with 16 of them, it'll take some time.
BUT
once you get the cams out you will want to plug ALL of the oil drain back holes in the lifter valley first (so if you drop a keeper it doesnt go "tingle tinkle tink" and make sure you are NOT hung-over or have the shakes because those damn keepers are SO ******* SMALL.
I use a magnet to remove them and a pencil eraser dipped in grease to install them. TEDIOUS WORK.
ALSO
Since you're likely using air-pressure to retain the valves in the cylinder MAKE SURE NOBODY STEPS ON OR DRIVES OVER YOUR HOSE!!
(Happened to me once)
Good Luck
WopOnTour
I decided to get the JBP HP Valve springs, they're going to be installed this week, gotta get my car in before Victory Red SS has his engine delivered, othgerwise I'll never get it done.
the JBP vavlve springs seem to be really well priced in comparison to the other available.
oh and I got Stage 2 cams. JBP will not be making a stage 3, he beleives they would have to be too agressive and would negatively effect the cars drivability.
how far do you thing I would be able to push may car no with the current internals?
LSX RWD S/C conversion
Originally Posted by player_1
I decided to get the JBP HP Valve springs, they're going to be installed this week, gotta get my car in before Victory Red SS has his engine delivered, othgerwise I'll never get it done.the JBP vavlve springs seem to be really well priced in comparison to the other available....
Originally Posted by Sinisterredlines
A few of us on the RL forums already have second engines with ported heads and many other goodies but alas we havent installed them into the car yet.
Change in plans, I'm switching over to the Bates valve spring and Titanium Retainer.
I decided just to spend the cash and beef it up.
I should be good for an 8K RPM limit now if I really want.
I'll probably get it tuned to 7500RPM just to be safe.
I should be good for an 8K RPM limit now if I really want.I'll probably get it tuned to 7500RPM just to be safe.
Sharkey
May 4, 2008 01:59 AM
