Vertical fin on front bumper
Old Apr 15, 2010 | 10:35 AM
vahdyx's Avatar
I noticed this vertical fin, I'm guessing the splash guard on the front bumper that hangs down approximately 4 inches. It scraps on everything, I don't know if it's my bumper scraping or just this fin.
Then I notice the OTTP car and a couple of others around here they don't have it.
How do I get rid of it? Is it even worth the trouble?
Old Apr 15, 2010 | 10:37 AM
Chevycobaltss3's Avatar
i just took mine off. it is gay but it is usful when a peice of somthing comes and hits your car and it breaks somthing because you didnt have that gaurd
Old Apr 15, 2010 | 10:39 AM
BLAZIN07SS's Avatar
I'm too JDM for you
it is meant to direct air to your radiator. leave it
1Quick07SS's Avatar
some call it a scrape guard, its just a piece of plastic that pushes cool air into your engine bay and stock radiator to cool things down a bit. It isnt absolutely necessary to have there, but GM did put it there for a reason. There are screws attaching it to the underside of the car, take those out and itll come right off.
haymakercobalt's Avatar
You talking about the fin that moves air up to the radiator?
Old Apr 15, 2010 | 10:41 AM
yeah its used for air, but its noticable when you hit somthing and before it breaks your oil pan, itll hit that and hopefully tear it off. lol. happened to me. lol
Old Apr 15, 2010 | 10:43 AM
PRND3L's Avatar
If you have a stock SS/SC, id leave it, you have a Heat exchanger and A/C condenser in front of the radiator, you are loosing airflow. if you run an aftermarket H/E and remove the stock one, i would get rid of it.
Old Apr 15, 2010 | 10:46 AM
dude just put the radiator and condensor on top of the hood lol. but at a stand still your car is not getting flow by movment of the car, so therefor the only time that is needed is when you are moving but you also have the fans/ front bumber air dam/ the grill, so it is really not needed to me at all, just a gm **** up like usual. lol
Old Apr 15, 2010 | 10:51 AM
BLAZIN07SS's Avatar
I'm too JDM for you
that doesnt make any sense. most of the aftermarket HE's are bar and plate which flow even less air through them. i would leave the fin on there
Old Apr 15, 2010 | 10:57 AM
rnjmur's Avatar
I wouldn't remove the fin. It is there to help direct air into the radiator when driving at slower speeds (under 40 mph). Without the fin there the car will not cool as effectively when you are driving at slower speeds.
If you drive all highway or drive above 40 mph all the time then you COULD remove it as it does nothing at those speeds.
Old Apr 15, 2010 | 11:02 AM
PRND3L's Avatar
The one I installed on Stealty1ss's car mounted below the bumper, catching its own airflow thru the lower grille.
Old Apr 15, 2010 | 02:51 PM
YzRider452's Avatar
When driving it bends back so i cant imagine it direct air torwards the radiator. It it was a harder plastic i would understand having it. Its pointless, throw it out.
Old Apr 16, 2010 | 11:05 AM
rnjmur's Avatar
See above ^
Old Apr 16, 2010 | 03:41 PM
vahdyx's Avatar
Soo... on the coolant temp reading, when does it overheat? I wanna watch this heat thing.
Old Apr 16, 2010 | 04:00 PM
loco-performance's Avatar
This and BLAZIN got the right idea. But it's your call.
Old Apr 16, 2010 | 04:06 PM
DVSk8er's Avatar
i took mine off when i went turbo cause it got in the way of interooler piping. on the couple 80 degree days on the highway and normal driving my temps never went over 195. sitting in traffic they go up but as soon as you get moving right back to 180
Old Apr 16, 2010 | 09:59 PM
rnjmur's Avatar
Overheating is 240 or above.
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
