Vibrant header
The vibrant setup is a combo, not just a header. Meaning it comes with a header and a downpipe. I have it and i think it sounds awesome and is definitely an improvement over stock. The only problem is that it has a small collector which will restrict you when you go for big power. I'd say anything under 270whp should be fine. I'm currently running a 2.8 60# setup and the collector hasn't been an issue yet.
The vibrant combo will still be fine at those levels. Just make sure you get some cooling mods cause the 2.6 will run the m62 real hot. As far as ZZP goes, they make great stuff so its your choice. Although I don't believe they offer their setup in stainless steel (however I could be wrong).
z28addiction
Sep 28, 2015 12:03 AM
