Vibrant Header and DP combo
Old May 13, 2008 | 07:50 AM
CobaltSSilver's Avatar
Any fitment issues with this setup on the SS/SC? I have a Corsa Touring and I'm considering this set-up. I don't want something that is going to not fit properly or is so loud that I get pulled over driving normal (under 3500 RPM)
Those that have this did it come with the gasket or does one need to try and re-use the old one? Also does it come with new flange bolts/nuts or no?
Old May 13, 2008 | 12:32 PM
cahtr6's Avatar
I just put mine on last weekend fit was great reused metal port gasket and nuts no leaks. Bolted up directly to my GMPP sport cat back. The only challenge I had was getting extra length on the back O2 harness. Sounds great nice low tone a lot louder than the GMMP exhaust manifold.
Old May 13, 2008 | 12:40 PM
KillerBee's Avatar
It does get loud when you start boosting
Old May 13, 2008 | 12:44 PM
BlilBT's Avatar
I love mine >> But like stated above it does get louder under boost.
Old May 13, 2008 | 02:09 PM
Is it loud enough to make you feel like it's illegal? Does it cause drone inside the car?
Old May 13, 2008 | 03:53 PM
chad463's Avatar
I dont feel like its loud enough to be illegal. The install was pretty straight forward but like said above the rear 02 sensor just reaches so you have to play with it for a bit.
Old May 13, 2008 | 09:50 PM
auggie_ss_phx's Avatar
i have mine hooked up to a ARK N2 Exhaust System and i like the way it sounds here is a clip of it on the road
http://videos.streetfire.net/video/c...ust_153520.htm
http://videos.streetfire.net/video/c...ust_153412.htm
Old May 13, 2008 | 11:02 PM
That sounds really good man!
With my Corsa not being as loud as your exhaust it sounds like I could live with the vibrant header and downpipe.
What are my options if I screw up the gasket taking out the stock mani?
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
