Video: Supercharger whine and some clutch slippage!
Old Feb 24, 2006 | 11:50 AM
BoomInIt's Avatar
Angry Video: Supercharger whine and some clutch slippage!
Here's a little run down the street with the clutch slipping. Sounds like a jet with the intake and stage 1.
StreetRun1
Street Run 2
You can hear the clutch through the shifts.
Old Feb 24, 2006 | 12:26 PM
fastSS06's Avatar
1st to 2nd sounds exactly like mine...........ordering my SPEC stage 2 and Fidanza Flywheel with tax returns, can't wait.
Gotta love that supercharger whine.
Old Feb 24, 2006 | 12:37 PM
Mines_Better's Avatar
does a slipping clutch sound the same as when a person rides the clutch too much when shifting? never heard what one sounds like...
Old Feb 24, 2006 | 12:48 PM
3fo893013L's Avatar
sounds like you let off the clutch too soon shifting gears and had already punched it going into second and rode the clutch instead of it actually slipping
Old Feb 24, 2006 | 12:49 PM
3fo893013L's Avatar
I was thinking the same. It sounds just like that... I would know because i've done it a couple times by mistake.
Old Feb 24, 2006 | 12:55 PM
same here, haha!
Old Feb 24, 2006 | 01:20 PM
BoomInIt's Avatar
Originally Posted by FAST06SS
Just a little FYI, have video for proof, i was rolling 15-20mph in 2nd gear, punched it, car hit the rev limiter and barely moved. My foot was no where near the clutch. It smoked so bad that my car stunk fo 3days! Next time it occured was at 45,ph, 3rd gear. I floored it, same thing, kit the revlimiter and went no where! If i nailed it at higher rpms/speeds, it would throw you back in the seat from the power! To me, that is a lack of clamping pressure!?
Similiar to my problem!
Stock clutch can't transfer the Torque properly without slipping. It has nothing to do how I shift if the clutch don't engage and transfer the power.
Old Feb 24, 2006 | 01:33 PM
Mercury's Avatar
Learn to shift better! Your clutch shouldn't be slipping like that. Or was your foot not on the clutch?
Old Feb 24, 2006 | 01:35 PM
BlackS/C's Avatar
I can't get it to work
Old Feb 24, 2006 | 01:39 PM
BoomInIt's Avatar
I can shift fine. My foot wasn't on the clutch. Its a stock clutch and it doesn't engage properly like Rob said "lack of clamping pressure."
Old Feb 24, 2006 | 02:16 PM
R33P3R007's Avatar
360 L337 User
I get that all the time when powershifting 1-2, but not 2-3 or 3-4 or 4-5. Is there anything we can do to increase the clamping power.
Old Feb 24, 2006 | 02:27 PM
fastSS06's Avatar
same thing here, only does it from 1st to 2nd.....other than that no problems.
Old Feb 24, 2006 | 02:58 PM
silverSS's Avatar
Merc you only have an intake correct? With a smaller pulley it is prominent even with the best driver. The clutch cant hold the power...And yes its only happens from 1st to second, no problem going through any other gears.
Old Feb 24, 2006 | 03:22 PM
BoomInIt's Avatar
Yeap seems to be happen frequent on the modded SS's and rl's. Increased clamping power=new racing clutch(stage 2 or greater)
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
