Water/Meth Installation Help please!!
Old Mar 27, 2008 | 12:49 AM
  #51
ssmokin's Avatar
Originally Posted by jimbos'ss
that makes sence that it would require a certain psi from behind to open it, what at the same time an equal amount of vacuum from the other end should in theory open the check valve as well. thats why i'm thinking he would be better off running it before the tb so the tb blade interferes with the amount of vacuum the jet is exposed to................like i said just a theory i'm working on.
yeah i guess the first step from here is to tune it and see what happens... i think it would be a lot easier to figure out exactly what we need to do after its tuned correctly...if it works great than no need for change...if it doesnt, then try other things... but until its tuned its all a guess IMO
Old Mar 27, 2008 | 12:53 AM
  #52
jimbos'ss's Avatar
true, if he's running that rich, he may have falled the plugs. something to check. but that would def cause misfires.
Old Mar 27, 2008 | 02:54 AM
  #53
stryder's Avatar
the plugs are kind of redish colored. and im gonna have to check on the nozzle tomarrow, I am running the 3 gph nozzle. thanks matt for filling him in. these are not big issues just adjustments LOL by the way i got a new phone a EN V made by LG its pretty cool.
Old Mar 27, 2008 | 03:24 AM
  #54
2K5SS/SC?'s Avatar
Ok then you are fine with the nozzle size. Please remove it from the adapter plate and do the trail spray like I suggested. I just want to make sure the ferrule is installed right and that I didn't have it backwards since it's been awhile now since I did mine.
What also could be happening is that the suction created behind the TB is overcoming the 16psi crack pressure of the checkvalve. I actually had the same issue when I tried to hook up my kit into the adapter plate below my twinscrew. I had to get an electric solenoid to control it that failed shortly thereafter, so I found a 25psi checkvalve to do the trick. It's just far easier to drill the intake like I did and put it in there. This is what I resorted back to in the end, and what currently works great for me.
Old Mar 27, 2008 | 03:30 AM
  #55
hungryhip-ccp's Avatar
that is from additives in our ca. premiumgas even with mine before the throttle body and a check valve if i take off the intake tube theres a small puddle there like engine vaccum is pulling the meth by the check valve... something i havent fixed yet either, but iv had no problems so far and not seeing a loss in fluid... dont know if this helps any? i need a tune for meth bad guys... can you help? im also thinking about joining!
care to share where?
Last edited by hungryhip-ccp; Mar 27, 2008 at 03:30 AM. Reason: Automerged Doublepost
Old Mar 27, 2008 | 05:53 AM
  #56
2K5SS/SC?'s Avatar
http://coolingmist.com/detailmain.aspx?pid=QBRCV01
It is a bit pricey, but it does work great and has the highest cracking pressure on the market. If I remember correctly, I got the nickel plated one with the ends. The cracking pressure is 22psi, not 25 like I stated before. The one that comes with the Devil's Own kit should work perfect though if the jet is placed in the intake.
Old Mar 27, 2008 | 09:12 AM
  #57
stryder's Avatar
hmm well i didn't drill a hole in the k and n but i did drill the stock intake and use that. ( I don't have a tap for the k and n) i believe the nozzle is spraying correct ly the slotted end is facing out and the othere ferreld end is facing in. anyway if i can get my k and n drilled and tapped it will be going back in today but yeah i think im not gonna use the adapter piece.
Old Mar 27, 2008 | 09:28 AM
  #58
kwest's Avatar
This thread has definetly some great info. in it. I as well aint to savy on the methanol thing, but i just got my AIS stage 1 kit like 2 days ago and im waiting for a free day to install it. After reading all this i feel alot more comfortable about how everything works and the install on it. Plus Rodney from the AIS team has helped me out alot, props to him!!! any of you guys running the stage 1 standard kit that taps into your windshield washer fluid tank that AIS offers??
Old Mar 27, 2008 | 09:35 AM
  #59
Werewolf SS's Avatar
I will be tommorow
After the install I'm also filling my tranny mounts and then that evening racing a Camaro for money
Busy day tomorrow.
Old Mar 27, 2008 | 10:56 AM
  #60
2K5SS/SC?'s Avatar
Before you drill into the intake can you please do the spray check first. This is just for my peace of mind. I want to make sure I'm not bass akwards on the ferrule. I wish I could just go to your house and take a look around the car and get it right for you. Internet instructions and lack of memory are owning me it seems!
Old Mar 27, 2008 | 12:35 PM
  #61
stryder's Avatar
LOL ok man when i get home today i will pull the nozzle off and see if it is spraying a mist or a stream. if i could get a little nut for the other nozzle I have i would use that one. its weird how DO uses outside nozzles they don't give you enough threads for the nozzle to really get a bite.
Old Mar 27, 2008 | 01:19 PM
  #62
jimbos'ss's Avatar
yah i noticed that about your nozzles, they have like 2 threads.
Old Mar 27, 2008 | 01:37 PM
  #63
2K5SS/SC?'s Avatar
The old nozzles give you plenty of room. I wonder if they can still get them. Sort of sucks that I miss placed my extra spares I bought. I need to find those bastards when I get home!
Old Mar 27, 2008 | 07:41 PM
  #64
stryder's Avatar
lol well i will have to figure out what size the nut is and go buy one real quick. i guess i had the switch turned up to high cus i wasn't spraying anything the whole way home.
Old Mar 27, 2008 | 07:54 PM
  #65
ColeJJones's Avatar
Bannned
good one luke
im still at work. this **** sucks. i see that you got the env. those phones are pretty sick. hopefully my AIS is like yours. should just be an hour install with mine. we'll see.
Last edited by ColeJJones; Mar 27, 2008 at 07:54 PM. Reason: Automerged Doublepost
Old Mar 27, 2008 | 07:58 PM
  #66
stryder's Avatar
well its supposed to only take a couple of hours but thats if you know where everything goes. I didn't but when matt gets his and you get yours install should be cake.
Old Mar 27, 2008 | 08:02 PM
  #67
ColeJJones's Avatar
Bannned
matt is jumpin on the waggon too. nice. what setup is he going with?
Old Mar 27, 2008 | 08:22 PM
  #68
ssmokin's Avatar
not sure yet.
Old Mar 27, 2008 | 08:26 PM
  #69
ColeJJones's Avatar
Bannned
ais is hella cheap. if i had the money i would have went with the snow set up.. if i had the mula
Old Mar 27, 2008 | 08:29 PM
  #70
ssmokin's Avatar
i like the fact that cooling mist has a stiffer check valve. and i like that i can get S/S braided lines from AIS
Old Mar 27, 2008 | 09:19 PM
  #71
Raven SS's Avatar
im sure if u contact rodney from ais he can come up with a check valve u will be happy with
Old Mar 27, 2008 | 09:29 PM
  #72
ssmokin's Avatar
you know me..im never happy
Old Mar 27, 2008 | 09:35 PM
  #73
Raven SS's Avatar
it happens
Old Mar 27, 2008 | 09:39 PM
  #74
ssmokin's Avatar
it happens
i may be leaning towards a trunk mount system..
Old Mar 27, 2008 | 09:42 PM
  #75
Raven SS's Avatar
trunk mount FTW!!
