Weird grinding coming from engine
Went to start my car today and it was making this weird grinding? Took it to get it looked at and they think its coming from the back of the engine. They didn't think it was the timing chain. Any ideas on what it could be? The car only has 35,000 miles on it so I'm not sure if there are problems that occur around that mileage.?
Car still runs and boosts just fine. Just don't want to drive it until I know exactly what's wrong.
Any ideas or input would be appreciated
http://i1051.photobucket.com/albums/...1/d8ae2066.mp4
I'm having problems with the video let me know if this works or not
i completely built/rebuilt my engine. new crank and bearings will cost you roughly 250-300. but you have to completely take off the bottom end of the engine. easiest if you take the engine out but possible to do in car
Yeah I'm really hoping that the timing chain tensioner is the problem I'm not excited about a costly repair so would it be smarter to try and replace the tensioner and see if that fixes the problem before bringing it somewhere to be ripped apart?
You can do it yourself also. There is a how-to I believe. That should save you a few bucks. Also buy your new part from RockAuto.com because you can get factory parts at shop prices aka cheap.
Timing chain tensioner is cheap. It's a 20-30 dollar part and just unbolt and bolt back in. If that doesn't fix it, then you probably spun a bearing. When mine spun, it sounded like it was on the top but tensioner was fine.
Well i took out the tensioner and i was just wondering if when you take it out is it supposed to be set or compressed out? when mine came out the tensioner was still set like the new one comes preset? any ideas?
