Well... that ain't good...
After a rough running, CEL flashing, barely making it home motor failure, I did a compression test to find 0 (zero) compression on the number 1 cylinder. All others were normal.
I took the motor apart to investigate. The #1 spark plug had broken apart, and looked like this...
After pulling the head, I immediately took a look to see if it were a problem with the piston and/or sleeve. All appeared just fine. I took off the oilpan and loosened the rod bolts to #1 and pulled the piston. Again, piston/bearings look fine and rings look fine.
Then I started wondering what on earth could cause a complete loss of compression, so I turned my attention to the head. I found the #1 exhaust port and looked at the valve, and noticed this...
Then I turned the head upside down and noticed this...
FML... I haven't heard of too many people blowing apart valves like this.
Damn Jordan I would have never guessed that. Kind of impresses me though that that is all that happened for what the motor has been through the past couple months. Do you think this was caused by your running lean up top issue creating too much heat. Or maybe the broken spark plug did the damage to the valve?
That's one for the archives!
Going to be hard to find root cause, but since the chamber isn't beat up by the piece of valve, I'd say it exited rather quickly. If you have a cat on the car, it should be laying in there.
2 scenarios:
Detonation caused the plug to fail and the piece of porcelain got between the valve and seat.
Or the valve just broke and the piece rattled around one time and broke the plug.
How's the piston look?
How were the rest of the plugs?
I'm assuming you have some mods on the car.
Ron
2 scenarios:
Ron
From what I can tell, I think the ceramic was pulverized to powder in the combustion chamber, as there is still debris on the piston. The big piece of the valve? I have no idea. I have the ZZP longtube and hi-flow cat. Could not find the broken piece anywhere, not even by the cat.
This was on cylinder #1. All the other cylinders/spark plugs look fine. The #1 piston looks fine, in fact I could have probably even left it in there and never took it out.
BTW, the car is modded just a bit
TVS, E85, 79 lb/hr inj, 2.7" pulley, LS4 TB, Diamond forged pistons (9.5:1), ZZP longtube header, hi-flow cat, full 3" exh, heat exchanger, dual-pass/opt B among many others.
I would not have guessed this. I thought for sure it would have been rings or sleeves that went, not the valve decapitating itself.
2 scenarios:
Ron
2 scenarios:
Ron
its not hard to find the root cause look at the pics they tell you what happened
valves dont break like that they melt away look in the pic of the exh port you can see where the missing part went. the engine running lean caused detonation which broke the porcelain of the plug and small and i mean small parts got stuck between the valve and seat and caused the valve to burn away look at the valve seat its black from overheating in a tight space (the small gap between the valve and seat caused by debris from the plug) so now you all have seen your first burnt valve courtesy of jordan
I'm a step ahead of you, buddy. I have searched for the missing pieces but they are nowhere to be found. I do have a hi-flow cat, and the ceramic I am pretty sure was pulverized to powder. The missing valve pieces are just gone. I don't know. I spent a good amount of time looking.
it looks as if the port ceiling and wall is damaged. Is it? If so I could smooth it back out. It's a perfect time to get a 3 angle valve job while it's off. I'd at least have the valves in that cylinder done
Thats weird. And your valves look a bit dirty for running e, normally they look pretty clean and not sooty. Almost makes me think there was either a low combustion temp issue or a high one. Low combustion temp would be from running no thermostat or a low one. High would be likely from not running enough spark advance or too much heat/boost/compression to be able to run enough spark advance.
I don't think there is an issue with not enough spark advance, I am running a TVS/2.7" with 25* timing at 12.0 afr (converted to gasoline afr's) and the cruise timing is set high to try for some extra mpg.
Motor is forged pistons at stock compression, boost is around 22-23psi with the TVS/2.7/ported head/3" exh.
sounds like to much heat to me. If you can't find the peice then its either gone or stuck in your cat or any muffler you have. Ive never seen this happen before... I'm shocked to be honest haha. Good luck with your fix man!
Also, do you think you could of had some valve float?
I don't think it was valve float, as I did not rev above 6500 rpms at all during the last 4 months due to the IDC's I was seeing on E85. Valve float would probably not happen unless you're well over 7k.
I don't think so. I knew that the IDC's would go over 100% if I went over 6500 so I just didn't go over 6500. I would usually shift at 6400 or so. IDC's would be right around 90% or so.
90BerettaGTZ
Canadian Mid East
Jul 3, 2006 01:26 AM
