Well, Doin the install myself...
That stupid ass mechanic i knew seemed to have backed out ... so it looks like im going to remove the sc myself, put on the pulley and put it all back together and make sure it works afterwards
So ive heard taking off the blower isnt that hard... some bolts and man power... but do the bolts NEED to be put back on at the correct torque, i dont have a tq wrench.... And i am renting a pulley puller from autozone and using an impact wrench from there on... I have to leave tomorrow for a trip and wont have time to take it to a machine shop, but that puller should also... "push" it on as well?
Any other suggestions would be kick ass.
Thanks
Andy
Thanks
Andy
i jut torque them down pretty good. not hella tight but tight.
oh ****... i dont know about pushing it on
no first the puller will not install the new hub unless its a supercharger puller/ installer which is what you'll need and the supercharger housing bolts must be tourqed to 18 lbs in with a tourqe qrench trust me you want one i already broke a housing bolt it wasen't hard to break either...and the puller if it 3 prong you must be careful not to ruin the threads on inside of the supercharger shaft or you won't be able to get the new hub on...save your self time money and a headache just get a supercharger puller/install smoothflow sells them for 99$
it really sucks to get the stock pulley off its a two man job.getting it on sucks but is much easier then getting it off.so use the right tools and make it easier on yourself
i actually have the smoothflow puller/installer i'll sell for 50$
If things dont go right tonight ill buy it.. thanks for the help! Im renting an actual pulley puller from autozone for 90 bucks... if i bring it back they give me money back... Ill let you know brett!
Andy
Andy
Delta coupe
09-30-2015 08:11 AM
