What are the best V-Grooved spark plugs
Hey guys, I am just wondering what the best spark plugs would be for my application. We are in the middle of our build and just to give a short run down of the mods are here. I would like to know what type of V-grooved plugs we should go with OTHER than NGK.
-Hahn stage V turbo conversion
-Port/Polished head
-Custom Comp cams
-Supertech 79lb springs
-Arp head studs
-Cometic Head Gasket
-80lb Siemens injectors
-Return style fuel system
-Walboro Moded fuel pump
-Devils Own Progressive Meth(100% Meth)
-Diamond ceramic top coat/teflon skirt coated pistons
-Total Seal Piston Rings
-3 angle valve job
-Exedy hyper single clutch
-Turbosmart Supersonic bov
-Greedy profec bspec II boost controller(approx 25lb boost we will run)
-HPTuners
Anyhow, I may have left a few things out but what I want to know is what you all think would be a great plug for our application. No offence but I would appreciate only the opinions of very mechanically inclined people only so this doesnt get carried away. We have went over tons of options but I would appreciate your guy's opinions.
-Port/Polished head
-Custom Comp cams
-Arp head studs
-3 angle valve job
-HPTuners
You just cant go and get ngk 2 step colder.. they are iridium, which isnt good for your application...
Your going to need to find copper 2 step colder plugs.
Last edited by ShortStack; Jul 23, 2009 at 09:44 PM. Reason: Automerged Doublepost
I did a little research and I did find these...
http://www.ngk.com/more_info.asp?AAIA=&pid=2763
NGK R5671A-8, 2 steps colder and copper
R5672A-8 is the part # you want
They DO make a non grooved resistor plug. BPR8ES.
what is wrong with iridium plugs in this application? aside from price
^ all copper plugs, btw
From the link from IonNinja:
Racing Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Non-Resistor, Solid Terminal, V-Power (V-Grooved Center Electrode), .032" (0.8mm) Gap, Heat Range 8
agentirons
Oct 16, 2015 02:11 AM
