what do the 2.9's do?
Old Jul 23, 2007 | 11:32 PM
craigk_c19's Avatar
compaired to the stage 2 3.0 other then its lighter what the advange to getting it? and how much does nate charge for a 2.9?
Old Jul 24, 2007 | 12:08 AM
07 SS/SC's Avatar
I believe nate charges 40$or 50$ for 2.9 pulleys (not positive on those prices tho) And a 2.9 pulley should give you "about" 10 additional WHP and a 1 to 1.5 more pound/s of boost.
Mike
Old Jul 24, 2007 | 12:14 AM
KillerBee's Avatar
Mike
Are you serious mike i need to get me one where do i go
Old Jul 24, 2007 | 12:17 AM
RedEcotecSS's Avatar
takes you up to 17.5 psi.
Old Jul 24, 2007 | 12:18 AM
KillerBee's Avatar
What if i run a 2.8 pully with gms 42.5 injectors and gms tune still good and safe or no
Old Jul 24, 2007 | 12:20 AM
jgarciarivera's Avatar
This is from Cobalt-addiction
CA SS GM STAGE 2 Replacement 2.79" Pulley
http://cobalt-addiction.com/performance.htm
This 2.79" pulley will fit the GM Stage 2 hub - It is made out of 6061 Billet Aluminum and Hard Anodized for wear resistance - There is 77.9 MM engraved on the face making it look like the stock 3" GM Pulley - It is CNC machine to 0.001" accuracy and designed to withstand high RPM - The side walls of the pulley are 77.9MM or 3” in diameter - The top of the groove has a diameter of 2.79” . These have been proven to run great on the GM stage 2 reflash as it is very rich fuel wise to start with and this will bring you right into the correct AFR . Will bump you up to 17.5psi !!!!!
Your Price: $69.99 USD + $9.99 Shipping
Jose
stock 06 ss/sc
Old Jul 24, 2007 | 12:43 AM
sealy's Avatar
nahh...i'm pretty sure the 2.8 should take you to ~17.5
Old Jul 24, 2007 | 01:37 AM
tlax23's Avatar
be careful with the 2.8" pulley
depending on your altitude, tune, and other factors you could run into complications.... with the gm stage 2 tune the injectors can have a very high IDC (injector duty cycle) at high rpm... the injectors go static (have no control) around 120%... just make sure you get the necessary gauges to monitor your car... a different tune can really help to maximize your cars potential.
it is not guarenteed that you will run into problems because every car is different... so far the 2.9" has been proven to be safe and the 2.8" is a very fine line...
Old Jul 24, 2007 | 05:51 AM
06blackSC's Avatar
Nate's 2.9 is an awesome pulley. he sells them for $50 for the standard and $55 for the high polished (which i bought). I did notice a little extra kick going from the stage 2 pulley to the 2.9. Boost for me reads around 17psi
Old Jul 24, 2007 | 05:59 AM
tum_tum's Avatar
yea you can split the difference go with the 2.85 from nate its great
Old Jul 24, 2007 | 07:09 AM
InfinityzeN's Avatar
Ignore all the people telling you to go with a 2.8X pulley. Without monitoring and possible tuning, your just asking for problems. 2.9" is far safer (notice I said safer, since even a 2.9" is not 100% safe). And *NO* the stage 2 pulley is not 3". It is 3.07", so closer to 3.1" then 3" flat. The stage 3 pulley is the 3" pulley (actually 2.99").
And as stated earlier, Nate's pulleys are $50 normal and $55 for the polished, which looks oh so pretty.
Old Jul 24, 2007 | 08:55 AM
sscobaltscZ06's Avatar
Thats why I went with a 2.85.... Right in the middle
Old Jul 24, 2007 | 08:59 AM
Onyxd04Redline's Avatar
Stay with the 3" and get...
Header
DP
Catback
TM removed
You'll be happier. So many of you just throw on a pulley first when you shouyld do supporting mods.
Old Jul 24, 2007 | 10:27 AM
light'bolt's Avatar
Sorry for the stupid question but who's nate, and where can I get a 3 inch pulley
edit: 2.9
Old Jul 24, 2007 | 10:35 AM
CTCOBALTSSS's Avatar
Header
DP
Catback
TM removed
That is great advice. Listen to the man.
At least do the supporting mods before the 2.9. That's what I did.
Intake and full exhaust before the 2.9 along with a tune afterwards.
Old Jul 24, 2007 | 10:40 AM
Yea, I pretty much had my GMPP Manifold, Exhaust, Stage 2, and Intake all put on the same day, along with the strut bar and rear sway bar. Wow, now that was a shocker.
Old Jul 24, 2007 | 10:51 AM
RuSSo-29's Avatar
Header
DP
Catback
TM removed
I saw this and I have I/H/E. The stage 2 will be ging in soon. So after that, the 2.9 or the 2.8 should be ok eh?
Old Jul 24, 2007 | 12:43 PM
KillerBee's Avatar
So will NATE 2.9 pully fit on the hub that came with the GM Stage 2
Anyone have the link to nates i am considering to get one like soon
Old Jul 24, 2007 | 12:47 PM
Blur.fx's Avatar
Pave It All...
http://stores.ebay.com/NHERBST454-Pulleys
All this talk of smaller pulleys and no one has mentioned any cooling mods?
Old Jul 24, 2007 | 12:58 PM
Yes his pulleys fit the GM stage 2 hub. Here is his info.
PM NHERBST454
nherbst396@yahoo.com
Nate
NHERBST454 Pulleys
Old Jul 24, 2007 | 04:07 PM
LopsidedJester's Avatar
Well, Crate Engine Depot explains that the gm stage 3 pulley which is 2.99" is the lowest you should go before doing cooling mods. I bought a 2.9" Nate pulley and i am planning on doing a dual pass which should be sufficient enough to keep from heatsoaking and what not.
Although, if you get a free-er flowing exhaust before upping the boost, this will help in cooling due to the easier expelled exhaust gasses and less pressure build up. I have a 3" catback and with my 2.9" pulley, i'm still only seeing slightly over 15psi max boost. Before my 3" catback i was seeing over 16 psi only with the 3" pulley.
Old Jul 24, 2007 | 04:12 PM
RuSSo-29's Avatar
So then I/H/E would be good enough supporting mods for a 2.9?
Old Jul 24, 2007 | 04:14 PM
well, i haven't had any problems yet, but i still wouldn't do a bunch of runs in a row. Intake supposedly promotes extra pressure build up too, but its negligible to what a nice exhaust headers and dp will help do.
Old Jul 24, 2007 | 04:15 PM
R&C_rallySS's Avatar
Header
DP
Catback
TM removed
I agree. +rep
Old Jul 24, 2007 | 04:35 PM
syP's Avatar
syP
my PSI still reads 15psi with my 2.90" from nate... boost gauge might be off a little??
