What downpipe?
Old Apr 17, 2010 | 09:04 PM
Caligula's Avatar
What downpipe?
I have a CA header, and A Megan exhaust. What downpipe would be bes for this set up?
Lookn at a CTI 3" but wouldnt a 3" lose hp?
And what about zzp?
Suggestions?
Old Apr 17, 2010 | 09:06 PM
GM COBALT SC SS's Avatar
your **** will be ultra raspy if you go catless. at least mine is with megan. even in the hottest weather. just a heads up.
Old Apr 17, 2010 | 09:07 PM
Caligula's Avatar
No way I am going catless. Forgot to add that. But thanks for the info.
Old Apr 17, 2010 | 09:10 PM
no problem. what are you gonna do with the stock cat?
Old Apr 17, 2010 | 10:37 PM
Caligula's Avatar
Keep it. Just in case I get any check engine lights.
Someone please give me some info about these things.
Old Apr 18, 2010 | 12:58 AM
1fastSSBalt's Avatar
I been asking around because I want a full exhaust system and I hear the ZZP has leaks but I'm not 100% sure =D....I was looking at Clear Image Automotive they have some nice stuff there check them out =D
Old Apr 18, 2010 | 01:14 AM
skatin_boarding's Avatar
I like my zzp d/p. Bolted straight up to ca header and stock axle back. Only their header/dp combos leak because of the 2 bolt flange from the header to downpipe.
Old Apr 18, 2010 | 01:20 AM
Caligula's Avatar
Wow, people actually talked. Thanks for the info.
I will look into clear image, if zzp leaks.
Old Apr 18, 2010 | 01:21 AM
Sizzle06's Avatar
I have the 3"zzp catless dp and it sounds fine with my ca v2 header and tsudo exhaust,no rasp at all.
Old Apr 18, 2010 | 02:39 AM
Caligula's Avatar
^ Some say it sounds bad, other say there isnt a big difference.
I want to keep the cat, becouse I need it where I live.
Old Apr 18, 2010 | 04:59 PM
Caligula's Avatar
Bump, would a 2.5 downpipe add hp?
Old Apr 18, 2010 | 08:07 PM
Exhaust is only as good as your most restricted area. So dp wouldnt matter if you have the 2.5" megan catback.
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 27, 2015 11:10 PM
