What DP is this?
Old Oct 30, 2010 | 04:27 PM
juice3's Avatar
Question What DP is this?
Anyone recognize this? This was on my car when I purchased it.
Old Oct 30, 2010 | 04:29 PM
Pedobear's Avatar
not sure but congrats tho
Old Oct 30, 2010 | 04:43 PM
383_Stroker's Avatar
looks custom (that looks like the stock flange on it)
Old Oct 30, 2010 | 04:51 PM
b00sted06ss's Avatar
ya if theres no brand on it then my guess is that its custom
Old Oct 30, 2010 | 05:18 PM
Tarheel62592's Avatar
its custom, you can tell cuz its got the stock flange and flex section, aftermarket cat and its crush bent
Old Oct 30, 2010 | 05:27 PM
ssyellow's Avatar
Yup, what you have there my friend is the stock downpipe flange (top right, 3 bolt) cut and welded up to some other piping down to the catback. Basically looks like you have 4 different sections welded up.
Old Oct 30, 2010 | 08:22 PM
SunburstSS's Avatar
Thats a bastard downpipe sir !
Old Oct 30, 2010 | 10:24 PM
juice3's Avatar
ok makes sense... previous owner had a custom exhaust basically... a little messed up tho... But would you guys say it's a good downpipe or no?
Old Oct 31, 2010 | 12:09 AM
SunburstSS's Avatar
Well the flex pipe " the top part is a little restrictive " depends on ur setup too ". it is crush bent and not mandrel bent so the exhaust velocity is even lower. I dont know how good the cat is it might be a high flow or just a replacement. I probably think it is a high flow...if ur stock i guess u can use it, if ur looking into modding i'd probably go with a zzp 3"dp or just a header/dp combo....
Old Oct 31, 2010 | 12:38 AM
juice3's Avatar
Okay, well i actually have ZZP header and megan racing exhaust. See I got ripped off by Zach. I just now noticed that he sold me stock downpipe when I thought i was getting ZZP header/downpipe... I am so mad right now. I thought i was nearly done with my car. All i had to do was put in the AEM wideband and get it retuned... but now I guess I will have to buy the ZZP downpipe.
Only good thing is now i can order it with the wideband bung. So since I have the ZZP header you think I should go with 3'' downpipe?
Also- the cat is actually fairly brand new.. I had to buy that cuz the last one was bad. Is there anything I could do with the downpipe or cat? Or is it just trash?
Old Oct 31, 2010 | 12:44 AM
BLAZIN07SS's Avatar
I'm too JDM for you
and zach screws over yet another person. yikes
Old Oct 31, 2010 | 01:05 AM
juice3's Avatar
well, I mean it was a while back. But I was nearly close to fixing everything up until I found this out ha
