What else to do to the Stage II
Ok, so I just seperated from the wife and actually have money to put into my car now. I will be spending about $1000 a month until it gets nasty enough to scare me (may be a while).
Currently has a XTC CAI Intake, and the GM Stage 2. I am not really good at the whole "get these parts in this order to reach this power". Ideally i'd like to be putting down about 300WHP.
I do use this car as a daily driver, and it does have to stay street legal.
What should I do to reach that amount of power without losing (to much) durability.
Yea, I was just looking at the zzp website, thinking of using this setup.
ZZP Mid length header and downpipe combo
-Model:1 3/4 inch Ceramic coated
-Option 1:Magnaflow cat
-Option 2:304 stainless downpipe
-Option 3:3" downpipe, 3" bolt in exit
ZZP 3 inch Stainless steel LSJ cat back exhaust
-Model:Whisper system
$609.99 and $599.99
$609.99 and $599.99
the zzp header and dp is nice.....I have that with the dc sports 2.5" cat-back and love it.
as for cooling mods.....another heat-exchanger would be a nice addition, and help to keep the IAT2 temps. down for the fun driving you do
ok first, what is IAT2 temp? Duel Bypass, and Devils own meth, what all does that involve, is it dangerous like nitrous? What size is the stage 2 pulley, should I go smaller? If I go smaller, would I need injectors bigger than the stage II injectors?
I've found most of the stuff, but no clue what order to do it all in.
IAT2, intake air temp. sensor 2...pretty much the air temperature being forced into your motor. You want to keep that as cool as possible. Running more boost will heat the air up so you want the dual pass or added heat exchanger to cool the air charge up. As far as a smaller pulley, the smallest I would go is mayyyybe a 2.9" with the stage 2 injectors. But I would get a tune anyways.
if I drop to the cobalt addiction 2.79", do I need to do anything with the belt? With a 2.79" and larger injectors, how soon after would I need a retune (no clue where to get one around here)
Nate
