what gap for a 2.9" pulley?
Old Jun 29, 2009 | 10:14 AM
kyle1853's Avatar
what spark plug gap for a 2.9" pulley i got the ngk copper 1 step colder (4644)? i have the gm stage 2 kit just incase you were wondering
Old Jun 29, 2009 | 10:15 AM
ShortStack's Avatar
.035-.038
Old Jun 29, 2009 | 10:18 AM
Staged07SS's Avatar
Administrator
Administrator
0.035 has always worked best on my car
Old Jun 29, 2009 | 10:29 AM
Zach06CobaltSC's Avatar
+1 for .035 that's what I run.
Short get on aim, brawr.
Old Jun 29, 2009 | 10:30 AM
kyle1853's Avatar
sweet thanks guys.. and what size is a 76 mm
Old Jun 29, 2009 | 10:32 AM
Staged07SS's Avatar
Administrator
Administrator
2.99" its GM's Stage 3 Pulley
Last edited by Staged07SS; Jun 29, 2009 at 10:32 AM. Reason: Automerged Doublepost
Old Jun 29, 2009 | 10:43 AM
kyle1853's Avatar
isnt the stage 2 a 3.0" tho
Old Jun 29, 2009 | 10:48 AM
ShortStack's Avatar
Stage 2 is 77.9mm.
Stage 3 pulley is 76
Old Jun 29, 2009 | 10:56 AM
Staged07SS's Avatar
Administrator
Administrator
If you want to be exact Stage 2 = 3.06"
Stage 3 = 2.99"
or what shortstack said: Stage 2 = 77.9mm, Stage 3 = 76mm
Old Jun 29, 2009 | 11:08 AM
kyle1853's Avatar
Stage 3 = 2.99"
whats that like a 1 psi difference maybe
Old Jun 29, 2009 | 11:44 AM
Staged07SS's Avatar
Administrator
Administrator
i saw about 0.5psi increase from the stage 3 pulley. it brings out the torque a tad sooner and it boosts faster. not a huge increase, but it deff. pulls harder than it did when i had the stage 2 pulley on.
Old Jun 29, 2009 | 12:28 PM
kyle1853's Avatar
did you ever run yours at the track?
Old Jun 29, 2009 | 12:32 PM
Staged07SS's Avatar
Administrator
Administrator
no i have not ....
Old Jun 29, 2009 | 01:26 PM
rukkee's Avatar
I used to see at least 1psi with my stage 3 pulley , when it was cold 1.5 . It definitely helps in the lower rpm ranges thou . My car liked .033 -.035 . The nice thing about the 76mm is it doesn't produce the heat a true 2.9 does , and even GM said it was safe for the stage 2 tune (stage 3 FAQ)
Old Jun 29, 2009 | 01:34 PM
Staged07SS's Avatar
Administrator
Administrator
i deff. agree about the cold weather. i would see as much as 16.5psi on a cool night, but my avg. psi with the Stage 3 pulley has been 16psi and it used to be about 15.5psi with the Stage 2 pulley. Still its a great upgrade and like you said it doesnt create the same amount of heat as the 2.9 nor does it strain the 42lb/hr injectors as bad. after all the gm stage 3 kit is designed for the 42lbers.
Old Jun 29, 2009 | 04:30 PM
kyle1853's Avatar
where can you get the stage 3 and how much ... i bought the 2.9 for 35 yesterday...but is the 2.9 alright to run?
Old Jun 30, 2009 | 07:12 AM
Staged07SS's Avatar
Administrator
Administrator
Some say its ok to run the 2.9 on the GM Stage Tune & Injectors, but I wanted to be extra safe. As long as you dont beat on your car all the time, you should be fine with the 2.9. To get the most out of the 2.9, its best to get a custom tune and larger injectors (ie. 60 lb/hr).
As for the GM Stage 3 pulley .... you can buy a genuine one brand new on Crate Engine Depot's website for about $120. Or you can have another company make you one that looks just like the GM Stage 3 pulley for $50 or so. I'm still under warrenty and the GM Stage 3 pulley looks identical to the GM Stage 2 pulley, so i shouldnt have any problems with the dealership if i ever need warrenty work.
Old Jun 30, 2009 | 07:54 AM
hawlyns711's Avatar
just some extra reference info....
Stock Gap is 0.45"
PSi-Fi Pulley Kit Recommendation gap is 0.28"
Intense-Racing GM-MAF-T/42.5lbs Injectors/2.8" Pulley Gap recommendations is 0.45"
South Florida Pulley Headquarters suggested NGK BK7RE gap is 0.35"
Old Jun 30, 2009 | 08:10 AM
Staged07SS's Avatar
Administrator
Administrator
Stock Gap is 0.45"
Intense-Racing GM-MAF-T/42.5lbs Injectors/2.8" Pulley Gap recommendations is 0.45"South Florida Pulley Headquarters suggested NGK BK7RE gap is 0.35"
stock gap is 0.039"
0.035" is a good place to start when you pulley down. 0.045" is much to large of a gap for a F.I. car.
For reference spark plug gaps are measured in thousandths of an inch not hundredths of an inch.
Old Jun 30, 2009 | 08:23 AM
hawlyns711's Avatar
I should have realized that mistake, but it was quoted from RLF...fail
Originally Posted by dL_RL
NGK BKR6ES *STOCK heat range* <-- STOCK Plug
NGK BKR6E "V-Power" *STOCK heat range*
NGK BKR6EGP Platinum Plug *STOCK heat range*
NGK PFR6T-10G "Laser" Platinum *STOCK heat range*
NGK BKR6EIX Iridium *STOCK heat range*
Autolite 3922 Copper Plug *One Range Colder*
NGK BK7RE Copper Plug *One Range Colder*
NGK BKR7E Iridium Plug *One Range Colder*
NGK BKR8E Iridium Plug *Two Ranges Colder*
NGK BKR9E Iridium Plug *Three Ranges Colder*
Denso Iridium IK24 *Two Ranges Colder*
Denso Iridium IK27 *Three Ranges Colder*
Stock Gap is 0.45"
For those of you running 2.8" or below. TWO RANGES COLDER IS RECOMMENDED.
The one stage is just not cutting it, well for me atleast here in California.
For those of you that want to go ***** to the walls like Jmc007 with the 2.6" Pulley. Do yourself a favor and go with the 3 ranges colder plug.
I personally am a NGK guy, i've had a bad experience with Denso (but I know they are a great plug).
I used the Autolites for like a day and hated them. Car felt like ****..
Anyone with anymore information to add, please do so..
and stock my Ion LSJ manual shows .045"............................................. ........you must have made that .039 up
Old Jun 30, 2009 | 08:31 AM
Staged07SS's Avatar
Administrator
Administrator
i made nothing up .... my 2007 Cobalt ss/sc manual says 0.039".
my plugs were gapped at 0.035" from the factory though, so who really knows the proper stock plug gap.
Old Jun 30, 2009 | 08:35 AM
hawlyns711's Avatar
yea to tell you the truth my gap was .042" when I got the car... weirdly enough. must be whatever feels the best
Old Jun 30, 2009 | 09:13 AM
rukkee's Avatar
Yep , here is the Service capacity's and spec's i pulled from GM Dealerworld Service Information. Look towards the bottom
Capacities and Specifications
Table 1: Engine Specifications
The following approximate capacities are given in English and metric conversions. Please refer to Recommended Fluids and Lubricants for more information.
Application
Capacities
English
Metric
Air Conditioning Refrigerant R134a
For the air conditioning system refrigerant charge amount, see the refrigerant caution label located under the hood. See your dealer for more information.
Cooling System
•2.0L L4 Engine Supercharged
9.2 qt
8.7 L
•2.2L L4 Engine
7.4 qt
7.0 L
•2.4L L4 Engine
7.4 qt
7.0L
Intercooler System 2.0L Engine
2.1 qt
1.95 L
Engine Oil with Filter
•2.2L L4 and 2.4L L4 Engines
5.0 qt
4.7 L
6.0 qt
5.7 L
Fuel Tank
2.2L L4 Engine (with NU6 emissions) sold new in CA, ME, VT, NY, NH, MA (see your dealer for bordering states)
13.5 gal
51.1 L
2.2L L4 Engine (without NU6 emissions) sold new in all other states (see your dealer for more information)
13.0 gal
49.2 L
2.4L and 2.0L Supercharged L4 Engine sold new in all states.
13.0 gal
49.2 L
Transaxle, Automatic (Complete Drain and Refill)
7.0 qt
6.6 L
Transaxle, Manual (Complete Drain and Refill)
1.7 qt
1.6 L
1.7 qt
1.6 L
Wheel Nut Torque
100 lb ft
140 N·m
All capacities are approximate. When adding, be sure to fill to the appropriate level, as recommended in this manual.
Engine Specifications Engine
VIN Code
Transaxle
Spark Plug Gap
2.2L L4
F
Automatic
Manual
0.040 inches (1.01 mm)
2.0L L4 (Supercharged)
P
Manual
0.039 inches (1.00 mm)
2.4L L4
B
Manual
Automatic
Old Jun 30, 2009 | 09:26 AM
kyle1853's Avatar
Stock Gap is 0.45"
wow where did you find this ...and in other words .035"
Old Jun 30, 2009 | 09:30 AM
Staged07SS's Avatar
Administrator
Administrator
i would go with 0.035" to start .... it has worked great on my car along with others
