What header gasket?
With your after market header what gasket are you using when you install it? I have asked in a couple other posts but got no answer. I am going to install mine in a week and need to know what to use. Thanks
my weapon-r didn't come with a gasket, i bought some heavy duty mr. gasket, gasket material from amazon.com which has the metal layer in it.
Mr. Gasket 5961 Ultra Seal Exhaust Gasket Material
got a 6x24 inch sheet and cut out the holes with a dremel, i don't know how well it will work yet. Cost about $20 including shipping, but theres enough material to make 2 header gaskets if you mess one up.
The GMPP Honed Manifold Gasket is the same exact gasket as stock, i bought one and compared them. Like 2K5SS/SC said, the primaries on most aftermarket headers are bigger than the stock gasket. It may not matter because the exhaust exits from the head aren't any larger, so it will still fit the engine and probably won't inhibit exhaust flow.
Sep 28, 2015 12:51 PM
z28addiction
Sep 28, 2015 12:03 AM
