View Poll Results: What oil brand do you run?
Amsoil
7.41%
Mobil 1
73.15%
Royal Purple
11.11%
Pennzoil
4.63%
Shell
0%
Walmart brand (lol)
1.85%
brad penn
1.85%
Voters: 108. You may not vote on this poll
what oil brand do you use?
Old Feb 16, 2012 | 02:27 AM
unijabnx2000's Avatar
Originally Posted by Sharkey
been using mobil 1 however next oil change im going to be using motul. mobil 1 is getting so expensive where i am, last oil change cost me $86. mobil 1 is now $13/l.
damn that sucks....
its 5 qt for about $28 here(walmart)
Old Feb 16, 2012 | 02:31 AM
minizr1's Avatar
Mobil 1 Fully Synthetic.
Old Feb 16, 2012 | 02:36 AM
sr20detpwr's Avatar
The factory recommended - 5w30 Mobile1 synthetic. I usually change my oil and filter out 2,000 to 2,500 miles depending on how I drive.
Old Feb 16, 2012 | 03:19 AM
Berto09ss's Avatar
been using royal purple
but i might switch to Mobil 1 extended performance
Old Feb 16, 2012 | 09:12 AM
cavfiredesire's Avatar
Try at Superstore.... cheapest place ive found it in the area. $45 taxes inc for a 4.4l
Old Feb 16, 2012 | 09:46 AM
insylem's Avatar
I use Mobil 1 5W-30 because the manual for the car says to.
Yes I know that Mobil just paid GM to reccomend their oil, but its still good oil.
Old Feb 16, 2012 | 05:42 PM
D_Rob's Avatar
Mobil 1. Because it matches my oil cap lol.
Old Feb 16, 2012 | 07:06 PM
turbosmart4's Avatar
im thinking of doin the same think!
Old Feb 16, 2012 | 07:09 PM
i had to add brad penn...
i looked at the options and saw that and i was like " it was a moderator "
Old Feb 17, 2012 | 04:04 AM
devilbmxer120's Avatar
I ran mobil 1 for 35k, switched to royal purple and theres a noticeable difference I think. MPG's are up 2-4 now, havent changed my driving habits. Real synthetic ftw
Old Feb 17, 2012 | 08:28 PM
  #36
but what can we use after 100k? the same thing? i want to know lol
Old Feb 17, 2012 | 08:36 PM
  #37
I dont see why not. As long as its not leaking anywhere, theres no problems running full synthetic the life of an engine
Old Feb 17, 2012 | 09:00 PM
  #38
so if i am running 5w-30 RP , its ok to keep using it and not switch grades?
Old Feb 17, 2012 | 09:12 PM
  #39
05Slowline's Avatar
lol
Old Feb 17, 2012 | 09:29 PM
  #40
nhanson's Avatar
Originally Posted by bobbyjohn681
does f35 take special gear lube or atf, if atf will end up with amsoil synthetic in there too lol
Only the F23 uses ATF for lube. Otherwise the F35 takes actual gear lube (dont remember weight)
Old Feb 17, 2012 | 09:55 PM
  #41
Sure
Originally Posted by 05Slowline
lol
Old Feb 18, 2012 | 11:50 PM
  #42
Flatgod's Avatar
I run Mobil1 in my car and truck. Amsoil in my bikes and 69 Corona. From all the reading I have done from independent testing Motul, Mobil1 and Amsoil are the superior oils. In the same studies royal purple was one of the poorest performers in all categories.
Old Feb 19, 2012 | 12:17 AM
  #43
SKY888's Avatar
Royal Purple XPR
Old Feb 19, 2012 | 10:05 PM
  #44
hmm im considering switching to amsoil...... hmmm
Old Feb 19, 2012 | 10:38 PM
  #45
Edubs's Avatar
Brad Penn...
Old Feb 20, 2012 | 04:14 PM
  #46
SaberD's Avatar
I use Amsoil.. In all honesty though, you can use any fully synthetic oil that meets the GM requirements until the DIC says 0% oil life, and then some.
The oil life monitoring system is a highly advanced system that was first designed for the C5 corvette. It was a first in the automotive industry. This same system has been advanced even more since then, and is used in our cobalts along with many other GM vehicles. It uses readings such as oil temperature/time, rpm/time, number of cold starts, warm starts, ambient air temp/time, time since last change, etc, etc. GM engineers spent years designing this system, and it is highly accurate. Anyone who changes their oil before the DIC says 0% is wasting their money. You can usually get about 12,000-15,000 miles out of any fully synthetic oil with zero negative effects.
Old Feb 20, 2012 | 10:29 PM
  #47
^^so u change it when it says 0%?
Old Feb 20, 2012 | 10:49 PM
  #48
I change it when its at 50% and thats usually 8-10k miles
Old Feb 20, 2012 | 11:08 PM
  #49
amsoil? i change it at 5k (royal p)
Old Feb 20, 2012 | 11:14 PM
  #50
mobil 1
