what the sh.t..witt!!
Old Jun 9, 2009 | 11:09 PM
  #51
WSFrazier's Avatar
Originally Posted by SK360
Wes's....
true story
Dan bought it for me... Was a gift.
Old Jun 9, 2009 | 11:11 PM
  #52
crIminal/SC's Avatar
wow i started this thread to find out what the **** is in my engine..lol not to talk about *****'s in engine bays..anyway i cant talk to witt cuz i dont know how to get a hold of him..wtf!..anyway stop the didlo talk n fill me in with some useful info!!!!!!!
Old Jun 9, 2009 | 11:13 PM
  #53
Tazmanian_Dvl's Avatar
We did. We told you that there's a ***** hidden in your engine bay somewhere! I just hope someone didn't confuse it with a camshaft!
Old Jun 9, 2009 | 11:16 PM
  #54
WSFrazier's Avatar
Here is a picture of said *****. It has been in every engine I touched. Including your's sir...
Do not try to deny it. Do not fear it. It is futile.
Old Jun 9, 2009 | 11:20 PM
  #55
Area47's Avatar
Rent me! per hour
if you, or al touch mine. the ***** will be left at home.
Old Jun 9, 2009 | 11:30 PM
  #56
WSFrazier's Avatar
When you feel that slight little touch on the ear from behind, you get a surprise greeting you in the face. Makes for some lulz.
Also, I think I'm done traveling for Ecotec work. Unless there are hawt red heads involved of course. Then I will buy the ticket myself. Pretty sure Dan would come too.
Old Jun 9, 2009 | 11:33 PM
  #57
Area47's Avatar
Rent me! per hour
the epicness of you or al coming to kc to build mine will be worth it anyways. getting through the gates with a ***** in your bags will create some lawls by the monkies doing the x-rays.
"whats this for?"
"for you if you play your cards right hot pants"
Old Jun 9, 2009 | 11:59 PM
  #58
alleycat58's Avatar
Originally Posted by WSFrazier
Only because he was behind the wheel, and I never had a chance to take it to the track.
Translation: The axels are safe.
Originally Posted by victoryss
WOW very true lmao! OP leave witt alone you already knew it was his when you purchased the car. You already knew it was heavily modded. You took the chance now you have to deal with it!
He didn't buy it from Witt. He bought it from a dealer, who should have been in the know about what was done to it.
Originally Posted by djt81185
that ***** was coiled in the intake and in the cylinders of my redline, in wes's engine and on his antenna, in a friends charger srt8 on the steering wheel to greet him in the morning after being in my engine the night before.
People have also been beaten with it and had it thrown it at em...it has some weight to it
Not to mention all the evenings of playing ***** dodgeball at MM.
You. Will. DIE.
"whats this for?"
I'll have to get together with Angie. We'll each plant something extremely homoerotic in each one's bag for the screeners to find.
Old Jun 10, 2009 | 11:29 AM
  #59
Witt's Avatar
Everything in your sig is correct plus an OTTP return fuel system which is set at 50psi base pressure (fuel pressure with vacuum line removed from the regulator) and tuned for such as well as their Walbro GSS342 255lph fuel pump and GMPP neutral balance shafts. Also has Intense Racing's solid front and rear trans mount inserts as well.
The MAF is tuned to run up to 25psi airflow should you switch to a larger supercharger such as the Harrop HTV-1320. The tune runs in MAF only mode and with the cams and return fuel system I wouldn't trust too many people retuning it.
The ***** never made it any further than the valve cover.
Old Jun 10, 2009 | 12:20 PM
  #60
if everything in my sig is right then why am i running a 1.9 60' then trapin in the 1/4 mile at 14.2 at 101mph
Old Jun 10, 2009 | 12:22 PM
  #61
elecblue06's Avatar
because you fail at driving lol .. you should be at low 13's with that .. actually mid 12s if you have a good suspension setup and some driivnt skillz lol
Old Jun 10, 2009 | 12:26 PM
  #62
lol if i fail at driving how could i get a 1.9 60'...i think i have heat soak??
Old Jun 10, 2009 | 12:28 PM
  #63
06blackg85ss's Avatar
lolz.... guess the harrop didn't make it to the dealership.
and that's it? you should be mid 13s with that trap
Old Jun 10, 2009 | 12:29 PM
  #64
elecblue06's Avatar
just means you are good out of the hole doesnt mean your not granny shifting and not double clutching like you should and that your shifting where you should be .. i could get a 1.6 60 ft but then shift slowly at 4k and run a 20 .. lol
yea i was like wtf i thought he had a harrop lol
Last edited by elecblue06; Jun 10, 2009 at 12:29 PM. Reason: Automerged Doublepost
Old Jun 10, 2009 | 12:30 PM
  #65
yea sucks the harrop didnt get to the dealership..but i should still be mid 13's...idk wtf is up
Old Jun 10, 2009 | 12:47 PM
  #66
PimpLay2's Avatar
guess we have to attack some ppl crim
Old Jun 10, 2009 | 12:51 PM
  #67
haha lets attack!...but anyway its not my driving..i have to things that it could possibly be..1-heat soak...or 2- im not shifting at rite time...when i got that time i shifted at about 6700...i can bring it all the way to 7500..should i?
Old Jun 10, 2009 | 12:52 PM
  #68
PimpLay2's Avatar
if thats what witt has the shift points at then yea.... he has upgraded valve springs right? if so i dont see a problem
probably heat soak... watch your IAT2's go do a third gear pull on the highway... you should NOT see 90+ at WOT
Old Jun 10, 2009 | 12:54 PM
  #69
Edubs's Avatar
You're definitely not taking advantage of the valvetrain and NBS'...
Old Jun 10, 2009 | 12:59 PM
  #70
Darkmanx's Avatar
subscribed for lulz
Old Jun 10, 2009 | 01:02 PM
  #71
Witt's Avatar
You can shift it at 8,200rpm. I did it everyday on that car.
No the TVS didn't go along with the trade. It was sold to a local Cobalt owner.
Old Jun 10, 2009 | 01:07 PM
  #72
so basically witt if i get a tvs then i wont have to mod anything or even tune it?? its alrdy set for a tvs?
Old Jun 10, 2009 | 01:11 PM
  #73
djt81185's Avatar
8200 rpm is rev limiter. Your car has 10:1 pistons (dual coatings) with total seals. In addition to springs it has the Ti retainers. Love how ur mod list keeps growing as ppl tell u what is in it.
And if you only getting low 14s its definately driver. rev it out to 8200 and try again
BTW i imagine if he still wanted to deal with the car he wouldn't have traded it in...
  #74
Witt's Avatar
If you keep the intake pipe and tune thats on it, no you wont have to retune it. The car originally had a 2.75" pulley on a TVS. The stock blower was swapped back on 2 hours before the car was traded in. The MAF was dead on when I traded it so I kept it as it was.
With the TVS and that size pulley, 50/50 water/meth or better was required to maintain the timing it is running.
Old Jun 10, 2009 | 01:26 PM
  #75
alleycat58's Avatar
Of your engine.
Guess not.
