what should i do???
Old Aug 11, 2008 | 05:55 PM
usdm08's Avatar
what should i do???
iam runnin a 2.7 pulley wit 42lb injectors wit gm tune n h/e , good or bad? cant get 60lb's have no way of tunein car wat should i do?
Old Aug 11, 2008 | 05:56 PM
mkulrey13's Avatar
Switch to a 2.9" pully and be happy. Your ruining your car running a 2.7. Its going to blow soon so switch fast!
Old Aug 11, 2008 | 05:57 PM
valentino0214's Avatar
find a place with a dyno and can tune your car... what hp and tq u trying to get?
restonSS's Avatar
yeah get a 2.9 or 3.0 in there asap. youre prob going static above 5500 rpms.
Old Aug 11, 2008 | 05:59 PM
2.7 isnt bad.. i got a 2.6, just get bigger injectors, a tune, and a dual bypass should be fine
Old Aug 11, 2008 | 06:02 PM
usdm08's Avatar
ive had the same setup for about a year already but iam gonna run more nitrous. why cant u run that pulley wit the injectors?
Old Aug 11, 2008 | 06:03 PM
restonSS's Avatar
bc it pushes too much boost and your motor wont get enough fuel aka you will damage something soon enough. thats a promis man. you either need
1. 60lb injectors and a tune or
2. 2.9 pulley and leave it alone after that.
Old Aug 11, 2008 | 06:07 PM
usdm08's Avatar
wat about a 2.8????
becuz iam doin 18psi off bottle n 20psi on bottle
Old Aug 11, 2008 | 06:11 PM
BLAZIN07SS's Avatar
I'm too JDM for you
let me put it to you this way... on a 2.9 pulley and gm tune, i'm at 122% injector duty cycle. imagine what your at with a 2.7
Old Aug 11, 2008 | 06:12 PM
restonSS's Avatar
you are welcome to do whatever you want man. we are all suggesting that you dont go any lower than a 2.9. you arent even tuned for it on the small 42lb injectors. you are pushing your luck. you are supposed to pull a degree or 2 of timing as well when you spray
Old Aug 11, 2008 | 06:13 PM
usdm08's Avatar
how does that injector duty cycle thing workin???? lol iam just askin alot becuz i dont wanna blow my motor.
Try2k's Avatar
Nobody has flamed yet...? 42's, 2.7, gm tune, and nitrous?
I'm am quite surprised... ss.net, please take your ***** back.
On the other hand, its somewhat nice for a change.
Old Aug 11, 2008 | 06:16 PM
restonSS's Avatar
i know right no flaming wow. anyways. the injector duty cycle % just means how hard they are working. ideally you want to be around low 70 ish % to be safe aka you need bigger injectors. yo uare well over 140% duty cycle aka pushing your stock injectors and getting incredibly lean up top. if you are going to stay with a 2.7 and not listen then you should get a meth kit and run like a 75/25 meth/water mix if not %100 meth to stop from blowing up. even then you need a tune dude. tunes are a massive part of performance
Old Aug 11, 2008 | 06:19 PM
usdm08's Avatar
i am dont worry. let me ask u something wats the normal temp that my motor she be at wit a h/e
n iam runnin really lean then?????
Old Aug 11, 2008 | 06:21 PM
restonSS's Avatar
depends. what temp are you talking about. there are at least 3 places i know of that you take temps from.
Old Aug 11, 2008 | 06:23 PM
Jkunzy1690's Avatar
get that 2.7 out of there.....consider it a grenade.... and the pin gets pulled a little more evrytime you punch it...... rip that thing out fast... and sell it
Old Aug 11, 2008 | 06:24 PM
usdm08's Avatar
the one it shows on the dash coolant temp
Old Aug 11, 2008 | 06:40 PM
Sinnah's Avatar
2.7, 42lbs, and nitrous. You said you've been running that setup for a year right??? how often do you punch your car???
Old Aug 11, 2008 | 06:44 PM
usdm08's Avatar
barely ever only when i race, i dont always spray i only drive my car fridays saturday n sunday
Old Aug 11, 2008 | 07:14 PM
Darkmanx's Avatar
Ill tune your car for 600 hundred ive been waiting to get a chance to see the faster cobalt in miami.
Old Aug 11, 2008 | 07:17 PM
Jimmys2007CobaltSS/C's Avatar
no no 2.7 on 42 and on gm tune yea listen to these guys either switch to a 2.9 or get 60's and have a custom tune or saygoodbye to ur car
Old Aug 11, 2008 | 07:19 PM
M-Dub's Avatar
42's are maxxed out with a 2.8 and meth!
Your motor sir, isn't going to last long!
Old Aug 11, 2008 | 07:56 PM
Maxim_X's Avatar
Buy a wideband and you will see for yourself how your safe your motor is. If it's over 12 at wot consider it's days numbered.
Old Aug 11, 2008 | 08:02 PM
usdm08's Avatar
wats a safe a/r
Old Aug 11, 2008 | 08:10 PM
Darkmanx's Avatar
wats a safe a/r
11.3 i would say for nitrous.
