What should my next mod be?
I'm looking for ideas on what my next mod should be? Some ideas I've had are dual pass, wot box, shorty header, meth, nitros. I'm looking for what would be the best thing to do with what I have done already.
If you wanted nitrous, thats something you consider seperate... Its either you want it or you dont.
Meth will need a tune. But will give you the best gains.
That header needs to go as well.
Dual pass is nice. WOT box is okay but... Id do the other stuff first.
OTTP rotated mounts if you're still getting wheel hop with your poly mounts.
Otherwise I'd go with a meth setup, even if you just spray water for cooling purposes.
Nitrous and or Meth would be a great mod. Meth is going to be a decent power adder and cooling mod that you can use on a regular basis. Nitrous won't be used all that often but its a nice kick in the butt when you want it however it costs more to setup.
I would go with meth first personally, nitrous is kind of the last ditch effort imo. Remember this is coming from someone who has both and runs both on a regular basis and has almost all the mods your talking about
