What size exhaust?
Old Jan 4, 2007 | 03:17 PM
D4u2s0t's Avatar
Originally Posted by Cobalt_SSTuner
ok, so say i went with a header that came out to a 3" outlet, to a 3" down pipe, and then go with a 2.5" exhaust. Think that would work?
the whole point of changing your exhaust is for it to be less restrictive... by starting with a 3" downpipe, then going to a 2.5" catback, youre creating the very restriction you're trying to avoid by swapping the pipes... i would keep it all the same size
Old Jan 4, 2007 | 03:20 PM
Cobalt_SSTuner's Avatar
so I guess I am gonna go 2.5" from header back
Old Jan 4, 2007 | 03:57 PM
3ds138's Avatar
Isn;t the stock exhaust already 2.5??
Old Jan 4, 2007 | 04:54 PM
D4u2s0t's Avatar
most of it, but the downpipe and i believe also the catback, but i could be wrong on that, go down to like 2 1/4 where they connect...
Old Jan 4, 2007 | 05:00 PM
3ds138's Avatar
cause of it is already 2.5 all the way back.. can we just change the muffler?? and then do the headers and down piping??
Old Jan 4, 2007 | 05:02 PM
Blown 4-banger's Avatar
Originally Posted by Bad06SS
Yes you lose torque, if you go from a 2.5" to a 3". Why else would DWK5150 be looking to go back to a 2.5" exhaust? New Era Performance, who's a vendor on here, dyno'd a modded Cobalt SS/SC. They started with a 2.5" magnaflow cat-back and went to a 3" cat-back. Again, this is a MODDED, pullied, cobalt, that already had a header and downpipe. They showed a 0 horsepower gain, and a 2+ft lb of torque LOSS ACROSS THE BOARD.
As for your comment about it being pointless to open up the flow before the cat, that just shows your ignorance on modding FI cars. Headers work great at getting rid of heat, decreasing boost, and killing KR. As for the JBP website comment, sure, if you go from stock to a 3" exhaust at the same time as you do the header, you're going to show gain. DUH. But if you do a test on a car that already has a header/downpipe, and then switch from 2.5" to a 3", then you'll see a torque loss. I've spoken to someone that had corsa, and then went to vibrant, and noticed a definete torque loss in the bottom rpms.
DWK5150 said he was thinking about going back to 2.5" for a little more low-end and because his 3" is too loud in his oppinion.
Old Jan 4, 2007 | 05:04 PM
shabodah's Avatar
My reasoning for going with the 3" downpipe and 2.5" cat back is because I don't have to mess with the downpipe later on if I want to swap things around. But honestly, I have a 3" exhaust on the Talon, and it's just too loud.
Old Jan 4, 2007 | 05:11 PM
IMO as long as it sounds good, I don't mind if its rediculously loud
Old Jan 4, 2007 | 05:14 PM
Bad06SS's Avatar
More "low end" is the key phrase.
Old Jan 4, 2007 | 05:15 PM
yeah, but he mentioned more for sound than torque
Old Jan 4, 2007 | 05:20 PM
  #36
D4u2s0t's Avatar
it's not 2.5 the whole way... it goes down to 2 1/4
Old Jan 4, 2007 | 05:21 PM
  #37
Bad06SS's Avatar
Yes, he has complained about sound. However, if you think about it, if sound was the ONLY reason, he'd just find a bigger resonator and a quieter muffler. I've talked with him via PM's, and he lost alot more low end torque than he wanted.
Old Jan 4, 2007 | 05:23 PM
  #38
If I'm not mistaken, on our exhausts we have one maybe even two resonators which are restrictive. Correct?
Old Jan 4, 2007 | 05:29 PM
  #39
1 resonator with a 2" flange
Old Jan 4, 2007 | 05:31 PM
  #40
Shortbus's Avatar
Iam currently in the process of re-doing my whole exhaust, 3inch is just to much for me, its loud, and the loss of torque down low is just a killer for me, iam doing a 2.5" header back, with cat this time, i cant stand the sound of this car catless, sounds like a honda buzing down the street.
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
