What size is the stock pulley
What size is the stock pulley on SS/SC and what size is the Stage 2 . I,m still trying to understand the size of the pulley how it affects the overall horsepower and Boost?
stock is 3.3" and stage 2 is 3.0 . I havent verified , but the general rule Ive read is 1 lb is boost gained per tenth of the pulley ( ie 3.3= 12.5 peak boost / 3.0 = 15.5 / 2.8=17.5 ect ect) How free flowing you intake is , and how free flowing your exhaust is will skew those boos#'s though . Freeing up on the intake side of the supercharger can "slightly" increase boost . Having a free'er flowing exhaust like a header , DP or catback will decrease boost pressure .
I have stage 2 and K&N CAI !
Do some searching in this forum . You will pull alot of useful info , there a million threads about stg 2 with smaller pulleys . In a nut shell though......Before you buy a smaller pulley , understand air/fuel ratio and why u should really buy a scan tool and wideband air/fuel guage before you get a smaller pulley . You should be re-tuned for smaller pulley as well . A 2.8 pulley in cold winter air with the stock stg 2 tune can run lean enuff to hurt stuff at 3/4 throttle or more
The wide band gauge is about 3-400 and a bit over 200 for a Aeroforce scan guage . Its alot , but knowing whats goin on with your car will save your ass down the road .
the stage 2 is slightly over a true 3", i would go with a 2.9 that fits the stage 2 hub. I think cobaltperformance cen help you out there.
You can go to a 2.8 on the GM hub, but there are alot of questions whether or not it is good to run the 2.8 with the stage 2 42# injectors. Most(me being one of them) people are seeing over 100% injector duty cycle.
And IDC ?
Intense sells a good wide band kit that comes with a retangular digital display . AEM also sell a Wide band meter that in a more conventional 2 1/16 guage ....anyone who sold AEM stuff would beable to get it .
Intense or Cobalt addiction and Im sure more vendors on here have the aeroforce guage .
Heck soon i'll be able to update my signiture Heck ya !
Again IDC's mean nothing with out a wide band because the GM 2 flash runs rich so if you told it to run not as rich with HPT theoretically your IDC's would go lower. I lot of this goes hand in hand with where your A/f's are at though. IDC"s IMO are based more on how much fuel enrichment your looking for not all about how much your injector can give evn though that is a factor too. Matter fact you need to look at all variables at the same time to come to any real conclusion.
I am DEF not trying to turn this thread into another discussion about this topic though.
ok just ordered them Now are they gonna be easy to install. I have only a small amount of knowledge about these things and truely I don't even know how to read either gauge but they are neccessary I understand that?
I agree, I was just putting it out there for consideration that it was a debate, i still haven't jumped on either side of the argument. Hopefully today I will get a chance to check out the AFR with the duty cyle to see if it can safely be leaned out any.
