View Poll Results: Which would you do with my mods?
JBP Tri Flow Cams and valve springs
12
25.53%
Tag Racecraft Whipple swap
26
55.32%
Tag Racecraft 2.7 pulley with custom tune and Water/Meth Injection
19.15%
Voters: 47. You may not vote on this poll
What would you do?
Old Jan 12, 2007 | 09:52 PM
JCswoosher2's Avatar
What would you do?
OK i have a lot of options. I can do one of the following above. my supporting mods are in my signature. With all these group buys. i dont know which way to go. My goal is 300 whp. Tell me which would you do and why. Keep in mind i have HPtuners so that part is easy for me. This will probably be the last mod to my motor so keep in mind. no internal work done. so being safe is important also
Old Jan 12, 2007 | 09:56 PM
Matty's Avatar
Cams.
Old Jan 12, 2007 | 10:23 PM
Scythe_Snake's Avatar
Whipple swap!!! Major gains. And sounds sexy!
Old Jan 13, 2007 | 04:22 AM
Cobalt_Supercharged's Avatar
You want to be safe at 300whp...do the Tag 1200AX swap. You will reduce your IAT2 underful boost and will be drawing less power from the motor to turn the S/C meaning more power to the wheels. The M62 at 12psi pulls just as much if not more power than the 1200AX at 22psi. To achieve you 300whp you should only need to use 15-17 psi meaning less draw than the M62 with the stock pulley!
Plus it gives you plenty of room to improve should you want to in the future without over spinning the S/C.
Old Jan 14, 2007 | 08:58 AM
man. not as lopsided as i thought it would be
Old Jan 22, 2007 | 10:08 PM
bump for more input
Old Jan 22, 2007 | 10:11 PM
DTM2188's Avatar
I voted for the cams!
Old Jan 22, 2007 | 10:14 PM
p7x's Avatar
p7x
Whipple man!!!, cams would be second. Think about it running something much more efficent, less work for the intercooler, lower boost, safer for compression. More hp than the other options. Only down side is $$$$
Old Jan 22, 2007 | 10:21 PM
SilverSS/SC's Avatar
I would do the Whipple . Youll easily make your target power # and the higher efficiency of the twinscrew should be alot easier on the engine than a overspun M62 . I dont see it in your sig , so I'll make the mention ....I would pick up a water injection kit as well if u can splurge .
Old Jan 22, 2007 | 10:57 PM
2K5SS/SC?'s Avatar
Lysholm 1200AX twinscrew swap from TAG FTW! I'm biased as you probably know!
Old Jan 22, 2007 | 11:05 PM
BACK2GM's Avatar
1200ax swap !
